Spool problem
发表于 2021-8-31 23:43:31 | 显示全部楼层 |阅读模式
I hauled my Lincoln MIG welder in my truck on a rough dirt road and my 12 lb spool unwound a bit. I pulled off what I thought was all of the tangled wire, but its grabbing or something. I can’t see any windings crossed, but it’s driving crazy.  I pulled some slack off and it seems to wield ok until the spool starts to turn. I don’t want to toss the spool because only light about 5% and I’m wondering if I can save it somehow. I wish now I would have saved a couple of 1 lb empty spools to transfer it to and I may have to buy one to use up so I can do that if I can figure out how to wind it on.
Reply:Sleeper  When this happens every spool unwinds a little different, so there isn't a perfect answer.If you are lucky, on an empty spool, you can unwind down to the hard-wind, than re-feedback with tension.  This has worked for me.How far down 'that rough road' did you drive?  Your spool may be 'fluffed' down to the core.If a re-wind doesn't prove promising, consider a total transfer to at least two other spools.Which ever you do, maintain tension [leather slip] and take care not to deflect the wire.Opus
Reply:I had that problem and fixed it that way but my spool was bent also i won't ever buy Lincoln wire againBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:ESAB seems to make some really good wire and electrodes.   can't get it locally thoughTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Thanks, I will give the rewind a try. It was along windy mountain road about 10 miles long. I’ve hauled the welder on dirt roads before, but this is the first time that I remember having a problem. I had tightened the spool down pretty tight before leaving and next time I’m going to have to remove the spool I guess. This is the first I’ve heard about Lincoln wire being bad
GMT+8, 2025-12-25 06:03 , Processed in 0.091188 second(s), 18 queries .
