TinMan
发表于 2021-8-31 23:43:28 | 显示全部楼层 |阅读模式
Has anyone watched the aluminum welding videos by Kent White of TinMan Tech. If so what is your opinion of them? Would you just rent them or buy them?Where do you find them?ThanksFrank
Reply:Originally Posted by frankrenoHas anyone watched the aluminum welding videos by Kent White of TinMan Tech. If so what is your opinion of them? Would you just rent them or buy them?Where do you find them?ThanksFrank
Reply:www.tinmantech.comyou can  rent or buy right from them. Yes its worth it.
Reply:Thanks!
Reply:Thanks for pointing out that rental option Aero. I'm not sure if it is a new feature, or not, but it looks like when you rent from Kent you get the option to buy. If you decide you want to keep the video, he gives you credit for the rental fee and only bills you for the rest. That's a great arrangement. I may have to order this 4130 series. Click on the rental terms to see the rent-to-buy deal. https://www.tinmantech.com/html/4130...oly_tubin.php#Lincoln 175HD Miller AC/DC ThunderboltSmith AW1, Dillion (Henrob) Mark III, & Smith LittleTorch
Reply:No Problem,  I think your going to see a lot more companies going to this to try combating the netflix type companies. I have heard that netflix and the like really screw over the people making technical videos.....and if there is no money to be made making videos.....whos going to make them?
GMT+8, 2025-12-25 09:39 , Processed in 0.091484 second(s), 18 queries .
