Cart Build
发表于 2021-8-31 23:43:24 | 显示全部楼层 |阅读模式
Wanted to say hello and post some pictures of a cart I am putting together to hold my mig & tig units, plus bottles etc. I have been reading here for a few month and thought I would jump in, I am not a pro but I do try and build most things if I can. I work at a chemical plant so there is no shortage of free scrap.... This build is from a filing cabinet, steel and a 55 gal drum dolley that I got from work. I have been working on it the last couple days for a few hrs in the evening, hopefully I will get done with it and put some paint on it this weekend. I am using my mig with flux core wire to put it together fast.
Reply:More pictures.........
Reply:Got the cabinet, welders and bottles just sitting on the frame to see how it looks. Also started working on the drum dolley to see how I will mount it. I have to modifiy it as it is to wide and there are cross pieces in the way that has to be cut out.
Reply:Very bueno JMann!Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Where did you get your casters?Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Originally Posted by Robert HallWhere did you get your casters?
Reply:Looks good - great idea w/ the filing cabinet.  I'd definitely put some chain or something around those bottles though.Millermatic 135Syncrowave 250
Reply:and a bumper rail around the caster perimeter.
Reply:Will definately chain down the tanks, I was just checking out how everything was going to fit. Like the idea of the bumper rail too! thanks
Reply:Well I finally finished the cart, I did not get to work on it much over the holidays. I finished it up and painted it yesterday and overall I am very happy with it. The filing cabinet works out great with those full extension drawers for storage. Below are some pictures of the finished cart.
Reply:That's a great cart.  I'm always amazed how people can look at "stuff" and turn them into awesome things.How's the balance of that with the drawers open in the last pic?  I guess the weight of the tanks offset the open drawers on the front?Lincoln AC225 and CartLincoln WeldPak HD and CartOne hand
Reply:It has great balance, the weight of the welders and tanks make it very stable when the drawers are open. It feels really solid when rolling it around.
Reply:Thats a great cart you built. I did something similar to hold my 5 x7 horizontal Band saw and it works good and gave me the storage I needed.Ray
Reply:Thanks for the kind words.........I am planning on doing the same thing for my BS too. I have another filing cabinet and it will set perfectly on top. May paint it a different color though.....
Reply:Great job on the cart JMann. Love your use of the 2-drawer.  I'm working on a couple generator load banks that will be using the housings of some discarded cabinets of which I have a few for such projects.Very well done!MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Finished job is just awesome. What did you use to paint it? Spray can? How many?Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:That's really neat, I really like your work table from the first few pics, guessing you built that too?
Reply:Originally Posted by Robert HallFinished job is just awesome. What did you use to paint it? Spray can? How many?
Reply:Originally Posted by MarcuspboldtThat's really neat, I really like your work table from the first few pics, guessing you built that too?
Reply:Nice. Here is a thread with mine, but not near as cool as yours. http://weldingweb.com/vbb/showthread.php?t=48529We are on our way to being farmers! Our site is always under construction so check back often for updates.  http://www.philosophyfarmstyle.com/
Reply:wow, that is super cool.www.dynamitedave.com
GMT+8, 2025-12-25 09:38 , Processed in 0.090847 second(s), 18 queries .
