查看: 2|回复: 0
More guessing
发表于 2021-8-31 23:43:23 | 显示全部楼层 |阅读模式
Can you make heads or tails of this one? Attached ImagesCommon sense in an uncommon degree is what the world calls wisdom.
Reply:Something agricultural?  Pusher attachment?
Reply:Bumpers for a loading dock.
Reply:High tech looking bull logo? (reference last pic) ChrisLincoln Pro Mig 180TMiller Spectrum 375
Reply:looks like an assembly jig for mounting pieces during fabrication or assembly
Reply:Ah, it's a rare double-V gusseted doo-hickey, next to a This-Month clipboard with some Camels on it.    The best laid schemes ... Gang oft agley ...
Reply:Looks like it slides down in a stake pocket on a truck or trailer ???Millermatic DVIMillermatic 251Older buzz box Cheap 120 welder
Reply:A holder of some sortThe Lord has declared, "This is my work and my glory--to bring to pass the immortality and eternal life of man"  Moses 1:39Link: My name is John, and I am a member of The Church of Jesus Christ of Latter-Day Saints.-- ColdCreekWorks.com --
Reply:Originally Posted by BrainfarthCan you make heads or tails of this one?
Reply:A bitch seat?
Reply:Coat rack?
Reply:It's a heavy duty one...(Retired) Professional firefighter, amateur everything else I try to do...Oh yeah:  Go Big Red!   (You know: one of the 12 members of the Big 10 cuz we left the 10 members of the Big 12...)
Reply:Some type of bracket that would mount to a truck or trailer on the double tube end and recieve sometype of equipment boom (crane) in the "u" flat stock area?
Reply:3 point hitch or similar. A bitch seat?
Reply:looks like a leg for a thingamabobMiller thunderbolt 250Decastar 135ERecovering tool-o-holic ESAB OAI have been interested or involved in Electrical, Fire Alarm, Auto, Marine, Welding, Electronics ETC to name a just a few. So YES you can own too many tools.
Reply:A hitch you could stand on for getting stuff out of truck?
Reply:I use to have that I would bolt under my ex-wifes chin.
Reply:Originally Posted by riceburnerI use to have that I would bolt under my ex-wifes chin.
Reply:How about a wheel stop, probably removable, to fit on a trailer when carrying one of those 'small' off-road vehicles ("ATVs).
Reply:Okay.. Here you go: Attached ImagesCommon sense in an uncommon degree is what the world calls wisdom.
Reply:Nice idea!(I still think it looks like a bull )ChrisLincoln Pro Mig 180TMiller Spectrum 375
Reply:Do ya think ya made it heavy duty enough to hold that ONE cylinder?! It sure looks good. I wish I had the patients to do that quality of work for something like that. It usually ends up being something I need NOW, and I slap it together. NICE work!"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Either that is a REALLY big cylinder or that is a mighty small bed!    The best laid schemes ... Gang oft agley ...
Reply:Dosent the DOT say that you are supposed to carry a cylinder upright?
Reply:Does it have an ejection button for those pesky tailgaters?DOT and OSHA cant make up their minds... Half of them say yay and the other say nay.  Had a federal osha guy bitch about an acetylene cylinder being on it's side, but no problem with the oxygen right next to it in the back of our truck.  I guess the guy really cares about our regulators (for every so much time on it's side, you have to stand it up for x times that time or the acetone will flow out with the acetylene and muck up your regulators.)It is a small bed.  I made it a few years back for a customer.  I pulled the whole build off in about 8 hours. Attached ImagesCommon sense in an uncommon degree is what the world calls wisdom.
Reply:I thought it was a chastity belt for a female bulldozer driver ...everything is temporary
Reply:Looks well built, that is for certain!
Reply:I meant to add, but I really like the design of the bed on th truck.  Any ideas on how much its weight compares with the original bed?
Reply:But, DOT is who is charge when you are transporting.
Reply:What OSHA says about moving cylinders.http://www.osha.gov/pls/oshaweb/owad...able=STANDARDS
Reply:Awesome work and a DANG good idea!
Reply:Jason:  I'm not entirely sure what it weighs, but 2 guys can easily pick the whole structure off by hand.  I'll keep toting my tanks the same way as everyone else.. Till DOT steps up to the plate and pulls over a NASA load, I'll keep it up.Common sense in an uncommon degree is what the world calls wisdom.
Reply:Cool idea but what happens if you slam on the brakes or hit something??????? I'm not seeing restriction from sliding forward enough to come out of bracket securing the bottom of the tank, or am I missing something??HH187Hobart 500i plasma cutterClark 4.5" GrinderDewalt 14" chop saw30 gallom 1.6 hp compressor10 gallon pressure pot sand blasterlots of hand tools
Reply:its not that the acetone will muck up the regulators thats a problem, the problem is if the acetone leaks out, the acetylene will become unstable and combust.
Reply:Brainfarth,How's that Trex working out for you? Have you gotten any grease or chems on it yet? It looks quite nice.Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
GMT+8, 2025-12-25 09:38 , Processed in 0.107822 second(s), 18 queries .
