switching polarity on Dynasty 200dx
发表于 2021-8-31 23:43:16 | 显示全部楼层 |阅读模式
I just bought a Dynasty 200dx. Do I just reverse the cables on the front for DC- vs DC+? I couldn't find any info in the manual about this. Only between A/C and D/C. thanks
Reply:On most Miller machines, just swap the cable positions.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:ye im pretty sure on that machine you just switch them if there is a switch it would be pretty visable like on the lincolin's there massive
Reply:Read your user's manual.The Dynasty 200DX will swap DC polarity automatically when you switch between SMAW and GTAW processes.When TIG high-frequency impulse or TIG lift-arc modes are selected, the electrode will be negative (DCEN). When you switch the output to stick mode the electrode automatically becomes positive (DCEP).Visit Tensaiteki.com
GMT+8, 2025-12-25 09:39 , Processed in 0.154918 second(s), 18 queries .
