Tig torch cooler
发表于 2021-8-31 23:43:05 | 显示全部楼层 |阅读模式
It's been a log while since I've logged onto Welding Web.  When I logged in todayI had several PM requests from other users to please re-post, or email picturesof the tig cooler that I built. So here they are !  .....Cheers  -Graham-Mechanical EngineerAutosport Mechanic/Fabricator
Reply:Great project, I would be interested in some specs from it, such as a spec sheet on materials, components if it wouldn't be too much trouble.Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:man, nice work!  how much money do you think you had into it?  If you did it again, would you build one or buy one?Millermatic 135Syncrowave 250
Reply:Originally Posted by mot krigman, nice work!  how much money do you think you had into it?  If you did it again, would you build one or buy one?
Reply:Thanks Graham, nice work.Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:very nice man i dont need a tig cooler but throwin out ideas.... unless some one wants to be lazy n buy 1 i have a brand new 230v coolmate 3 in the box still 500     do you think you could just use a fuel pump and regulate it wit a fuel regulator? it kinda looks like the set up u have in you tank
GMT+8, 2025-12-25 06:03 , Processed in 0.089706 second(s), 18 queries .
