Where to buy 5" aluminum square tube?
发表于 2021-8-31 23:43:03 | 显示全部楼层 |阅读模式
I have looked at every place I know, but where can I find a piece of 5" square aluminum tube with 1/8" wall?Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:www.onlinemetals.com list 6061 at 5"sq x .25 wall.
Reply:That's too thin, I want a thicker wall like .100 or .125Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:is 1/4" wall  too thin or too thick?
Reply:Too thick.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Originally Posted by GambleToo thick.
Reply:Gotta find it first Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:good luck finding that...You might see if a local metal shop can find it for you.Miller Dynasty 200Millermatic 211Instagram?.... find me @ WELD_MEDIC
Reply:Loxcreen has 4 x 4 x .125
Reply:Where I worked we got in sq. tube anywhere from 1/2" to 6" Sq. most of it came from Alcoa.I would google there website the list all sorts of shapes and dist.
Reply:In chicago I would try Ryerson's
Reply:www.specialtymetals.com  Not sure if they ship though.-AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup
Reply:Originally Posted by tapwelderwww.onlinemetals.com list 6061 at 5"sq x .25 wall.
Reply:haha, your right. I want thinner. I want 1/8 or slightly thinner.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Try Marmon Keystone. They have facilities in Bolingbrook and Spring Valley.www.marmonkeystone.comWorth a phone call.AlA man is judged by what's between his legs...always ride a good horseMiller DialArc HFLincoln Classic 300DThermal Arc 181iPowermax 45Scotchman Ironworker(2) BridgeportsOkomota Surface GrinderAutoCAD 2010
Reply:^ I will call them today.Local store never called me back These guys seem to know where to get some apparentlyhttp://www.ebay.com/itm/Oil-Breather...70903585965%26Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:I'm wondering if they simply had a sheet bent that way and you can't see the weld on the lower seam on the far side. There would only be one weld that way and fairly easy if someone had access to a brake.You can also get just about any shape you want done in an extrusion if you purchase a large enough quantity or pay enough for the single piece. Many times you'll find production parts in nonstandard shapes, sizes, thicknesses simply because the cost savings on materials outweighs the cost for setup/tooling to get the material made or to fab the part up in a more conventional manner. They may not even be the one who has this requirement. They may simply know someone who has that particular shape/size as their "standard" and they are buying shorts the other company is scrapping. I've seen several "production" jobs set up around readily available "scrap"..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
GMT+8, 2025-12-25 07:49 , Processed in 0.069388 second(s), 18 queries .
