查看: 13|回复: 0
What is back stepping your weld?
发表于 2021-8-31 23:43:01 | 显示全部楼层 |阅读模式
Seen that term get tossed around here a few times but I haven't a clue what is it. Can someone else what it is and why you do it?Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:1st weld)))))))))2nd weld))))))))3rd weld))))))))Buy American, or don't whine when you end up on the bread line.
Reply:Gamble,  See the provided link. It is a weld progression utilized to minimize distortion.http://www.lincolnelectric.com/en-us.../arcblow10.gifjrw159
Reply:doubleLast edited by WeldingMachine; 09-26-2012 at 06:07 PM.Reason: X2..Buy American, or don't whine when you end up on the bread line.
Reply:In a hobbiest terms. It's welding back toward the previous weld. Say you're welding two sheets of plate together with a solid weld. You start at the end of the plate and you're working your way across the seam. so instead of starting at the edge of the plate, you start and inch or two in and weld toward the edge of the plate. Your next weld then starts a couple inches past the starting point of the original weld and moves towards the first weld. and so on and so forth. it keeps the heat in the welded area causing less distortion.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:It is a method of starting and stopping your weld.  When you start a weld you get a lot of heat and not much metal and the zone is subject to cracking. You start your weld move forward then back to fill the crater, the same when you finish a weld you leave a crater of heat with no metal so you go back over the weld to fill in the crater.  When a pipe welder starts a pass he will usually strike on the side of the joint move forward to get a puddle then back to fill in the crater.
Reply:Originally Posted by GambleSeen that term get tossed around here a few times but I haven't a clue what is it. Can someone else what it is and why you do it?
GMT+8, 2025-12-25 07:57 , Processed in 0.081999 second(s), 18 queries .
