CK Amp Control To HF-251D-1
发表于 2021-8-31 23:42:58 | 显示全部楼层 |阅读模式
The 14 pin connector on the ck rotary amp control has a ground strap coming off of it that they want you to connect to "earth ground" which wouldn't be a problem if I was plugging into the tb302 but its being plugged into the high freq arc starter and I don't know where the ground strap should get connected to does anybody have an idea?
GMT+8, 2025-12-25 06:15 , Processed in 0.095124 second(s), 18 queries .
