i got 316ti stainless and s235jr for position B , thickness : 6mm , process manuel tungsten inert gas. do i have to make a buttering layer ?or 309 wire is enough without buttering layer
Reply:Think I'm missing something in the translation... but are you asking how to weave with tig? o.Oonly heard buttering used (hardly ever) as a term to describe a weld... usually a weave.
Reply:when welding ss to mild, you butter the mild with 309 and then weld the two togetrher with 309. hope that helps
Reply:You may find some helpful inf from thread I posted.http://weldingweb.com/vbb/showthread.php?t=35065Miller TrailBlazer 251Miller HF-250-1Miller MaxStar 150 STLHyperTherm PowerMax 380 plasmaLincoln PowerMig 180Millermatic 252Miller Diversion 180
Reply:thank you all guys ! it was an emergency for the moment and then we decided that it was not very critical part and so we did it without buttering layer and just a 309 wire . thanks for your helps. |
