Day 2 slightly less pitiful beads
发表于 2021-8-31 23:42:52 | 显示全部楼层 |阅读模式
3/32 6011 on clean metal. 40 amps3/32 6011 on dirty metal 40 amps1/8 6013 on clean metal 80 amps1/16" 6013 at 30 ampsI'm sure I am trying to do to much.  My starts and stops on most of these beads are bad, build up heavy to begin then crater at the end.  Still think overall was a bit better than yesterday.
Reply:I fail at 6011's so looks good to me lolMiller Thunderbolt Craftsman Flux core mini migVictor cut skill torch
Reply:I wouldn't exactly call that clean metal. You should grind it till its shiny clean metal. That metals also so thin its going to be difficult to learn on. See how the begining of your welds start very cold and by the end are on the verge of blowing through? The metal just heats up too fast for stick. And the last consistent weld is waay too cold
Reply:you're comin' along. just don't expect it to happen overnite. keep practicing and keep the arc tight. the shorter the arc, the less heat, relatively speaking of course.and once you've mastered arc control consistently, then start playing w/ amp changes.i think once you have the arc control, then you'll find you don't need near the amps you think you do.                                        mikeLast edited by mla2ofus; 01-03-2011 at 08:52 PM.Ol' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Those amp ranges sound low to me, but if you crank your welder up, you may blow through your thin material. You might want to get your "clean" metal cleaner. Flap discs (Angle grinder wheels with sandpaper on them) take rust/paint/etc off faster than anything else that ive ever used. You also seem to be going to fast to me, but im no expert. Looks like you're having fun :-)[Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
Reply:from some of the pics your doing good   use all of the electrode dont just do 1 inch beads but yes  grinder --- we dont see any grinding /cleaning even running stringers ya need to get to bare metalidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:Originally Posted by SR20steveI wouldn't exactly call that clean metal. You should grind it till its shiny clean metal. That metals also so thin its going to be difficult to learn on. See how the begining of your welds start very cold and by the end are on the verge of blowing through? The metal just heats up too fast for stick. And the last consistent weld is waay too cold
Reply:would appreciate if SR20steve or anyone experienced would explain a bit what are the signsof :"begining of your welds start very cold" "by the end are on the verge of blowing through" - I guess you mean too hot/too slow"last consistent weld is waay too cold"-learning on my own/can't see/tell the signs
Reply:Originally Posted by vjekowould appreciate if SR20steve or anyone experienced would explain a bit what are the signsof :1.   "begining of your welds start very cold"2.   "by the end are on the verge of blowing through" - I guess you mean too hot/too slow3.   "last consistent weld is waay too cold"-learning on my own/can't see/tell the signs
GMT+8, 2025-12-25 06:15 , Processed in 0.095834 second(s), 18 queries .
