just another welder cart
发表于 2021-8-31 23:42:48 | 显示全部楼层 |阅读模式
This is my welder cart I decided to throw togather today. Heres a couple pics. I need to add some kind of mount to coil the wires on. any ideas?? thanksoh by the way sorry about the messy shop. Attached Images
Reply:Sorry gotta say it, CHAIN THAT TANK! As for a whip holder a hook on the side of your handle might work.  Other than that Nice jobRyan_______________________OF COURSE I DON'T LOOK BUSY... I DID IT RIGHT THE FIRST TIME
Reply:thanks ryan. yea i put a bungee on the tank after i took the pic. do you think 1 hook will be fine or should i make some kind of loop like a water hose hanger? thanks
Reply:I don't really know if it were me I would put one hook on each side, one for ground and input power and one for the whip. A garden type hanger would work good. If you have an old wheel rim you could cut it in half and put half on one side half on the other.Ryan_______________________OF COURSE I DON'T LOOK BUSY... I DID IT RIGHT THE FIRST TIME
Reply:ok thanks, i think ill just put a hook on each side and be done with it. I used stainless steel paint. i really like how the paint turned out. thanks again.
Reply:Here is my rookie welding cart I builthttp://weldingweb.com/vbb/showthread.php?t=48529We are on our way to being farmers! Our site is always under construction so check back often for updates.  http://www.philosophyfarmstyle.com/
Reply:I like your design, simple, light, and neat. Best, Ralph
Reply:thanks ralph, it is a simple design. i wanted to keep it low to the ground so its not top heavy but still get easy axcess to the front guages. this is what I came up with. the shelf in the front is to hold my bottle guages when not in use. thanks.
GMT+8, 2025-12-25 07:49 , Processed in 0.093580 second(s), 18 queries .
