Linde Migmaster 225 Spool gun control
发表于 2021-8-31 16:58:48 | 显示全部楼层 |阅读模式
Hello all I am looking for a spool gun control panel for my old 225.  Who out there has one collecting dust?
Reply:Just mount a switch and receptacle in the cover plate and wire it up by the diagram.switch might be a 4 pole switch. Should be able to buy receptacle online by the number on the blue insert and a panel mount shell.
Reply:Hey thanks.  I think i have a plan. This control panel has a fair amount of equipment behind it to run the spoolgun. I am going to have to add some contactors to run my airco MIGeT to get the voltages correct.
Reply:May want to talk to profax lenco tech support about your spoolgun.Find out what it needs to operate. There are several versions. one uses weld voltage and some use 24vdc or other voltage.I believe they built it for Airco.
GMT+8, 2025-12-19 01:53 , Processed in 0.127529 second(s), 18 queries .
