5g covers
发表于 2021-8-31 23:42:40 | 显示全部楼层 |阅读模式
Just messing around (I also don't know the best area to put this)...had the opportunity to go to a union school and play around with materials/machines.  Never recorded video with my phone either and wanted to see it's quality, I guess if I ever cared to record welding I should set up a lens in front of it .  Any and all comments/help/****-talking are welcome
Reply:Thats a sweet weld how and what did you learn to walk the cup on what was your light bulb moment with it im having so much trouble walking it and what cupe sizes did u use for root cap etc
Reply:Originally Posted by BozzzaThats a sweet weld how and what did you learn to walk the cup on what was your light bulb moment with it im having so much trouble walking it and what cupe sizes did u use for root cap etc
Reply:Not bad, but the cover looks really wide for sch80.  Im assuming 37deg bevel on both sides about 3/32 open root?  My cover beads look to be about the same size as your with the same amount of overlap and I only need 2.Maybe the video is deceiving, but thats the only thing I noticed other than it could straighten out a little.One of the last 5g covers I did.Have we all gone mad?
Reply:lol im so envious of both of use i have started walking the cup on 3mm wild steel sort of gettin the hang of it im a bit jerky tho also what amps do you run of cap and root with 2.4 tugsten and 2.4 fill for cap and root?
Reply:Originally Posted by sn0border88Not bad, but the cover looks really wide for sch80.  Im assuming 37deg bevel on both sides about 3/32 open root?  My cover beads look to be about the same size as your with the same amount of overlap and I only need 2.Maybe the video is deceiving, but thats the only thing I noticed other than it could straighten out a little.One of the last 5g covers I did.
GMT+8, 2025-12-25 09:38 , Processed in 0.090730 second(s), 18 queries .
