International water truck
发表于 2021-8-31 23:42:30 | 显示全部楼层 |阅读模式
There's not much welding, altough i done alot of it, on this project page. It wasn't meant to be shown but i figured it could be of intererst to some of you, big machines, scorching flames, molten metals lovers. It's the second truck exactly like that that i done.Here's a project i recently had to do at work, the truck was originaly a 6 wheeler that i converted into a 10. There's also the matter of lengthening the frame (added 23 feet), aligning it perfectly, welding and buffing then doubling it with press brake bent 1/4 stock. Drilling the holes for the suspension, adjusting everything... it's quite a modification of a vehicule.Then there's the water tank and extra huge fuel tank that goes on it.The truck is for a client that exports them to the african continent.Here we go with the pictures... Attached ImagesLincoln Ranger 250Lincoln LN-25 Across-The-Arc FeederMobile Unit / Workshop (drill press, air, welding, horiz bandsaw...)[SIGPIC][/SIGPIC]
Reply:set #2......... Attached ImagesLincoln Ranger 250Lincoln LN-25 Across-The-Arc FeederMobile Unit / Workshop (drill press, air, welding, horiz bandsaw...)[SIGPIC][/SIGPIC]
Reply:set #3....i don't have the entire completed project as i forgot to take pictures of it... sorry :/the truck has set sail to africa by now. Attached ImagesLincoln Ranger 250Lincoln LN-25 Across-The-Arc FeederMobile Unit / Workshop (drill press, air, welding, horiz bandsaw...)[SIGPIC][/SIGPIC]
Reply:Pretty spiffy!  Love stuff like this, thanks for sharing.MikeConstans Fides et IntegritasLincoln Weldanpower 150 ACAirco Aircomatic MIGet CAV II w/ spoolgunMillermatic 30a wirefeeder
Reply:Cool. What kind of suspension is that. I think I've seen them on cement mixer trucks.  Is it air or just a walking beam with rubber pads?"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Originally Posted by Stick-manCool. What kind of suspension is that. I think I've seen them on cement mixer trucks.  Is it air or just a walking beam with rubber pads?
Reply:Ugh the walking beam.   Just looking at that makes me want to find a high school kid to whack my kidneys with a baseball bat to remind me why i hate that suspension. They are a fantastic suspension setup for speeds under 25mph and off road.    Second only to the mack camel back suspension.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:we used to call em block pads. no broken springs like reyco's when your overloaded or in the rough. pigpen
Reply:Originally Posted by DualieUgh the walking beam.   Just looking at that makes me want to find a high school kid to whack my kidneys with a baseball bat to remind me why i hate that suspension. They are a fantastic suspension setup for speeds under 25mph and off road.    Second only to the mack camel back suspension.
GMT+8, 2025-12-25 11:30 , Processed in 0.102506 second(s), 18 queries .
