330ab/p technical manual available
发表于 2021-8-31 23:42:23 | 显示全部楼层 |阅读模式
if anyone is interested i have a pdf tech manual that i can share.Dynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
Reply:There are a few people around with these machines.Im sure someone will ask soon.
Reply:Send a P/M to member 7A749...He will help you out....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by zapsterSend a P/M to member 7A749...He will help you out....zap!
Reply:I just woke up..Good call Larry.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:indeed, i talked the miller rep into sharing because the local repair shop declined to work on my machine; so i thought i could share the wealthDynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
Reply:up here they get big pipeline contracts and stuff so they dont care to spend time on older machines that they deem not worth having.no spark is the issueDynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
Reply:I have a 320 and would be interested in the PDF manual.  I think the 330 and 320 are almost the same with just more amperage for the 330.  I have a paper copy of the manual (I think both the 320 and 330 are in it) but I tend to loose papers.  I can catalog and save stuff easier electronically.austingerding at hotmail dot comthanks!Racecar FabricationOld Miller 320 A/BP TIGMiller 140 MIGwww.f-bodysport.com
Reply:If you don't mine I will appreciate a copy for troubleshooting, the users manual is not enoughrrelectricrepairs at gmail  comThanks,RR
GMT+8, 2025-12-25 09:39 , Processed in 0.093252 second(s), 18 queries .
