Cold Hood
发表于 2021-8-31 23:42:22 | 显示全部楼层 |阅读模式
Does it cause problems with a AD Hood, Being stored outside below 32ºThanksThe main thing is not to panic or get excited Bobcat 250, X-Treme 12VS,  MM211Meltabo, Milwaukee,Porter Cable,Dewalt,MakitaVictor O/A, Ingersoll-RandEvolution Rage2, 40 amp PlasmaLincoln 225 AC/DC
Reply:batteries are batteries... So I would check the specs on the batteries. I don't know about the screen, on if it's effected by temp.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Renagade, I have an Speedglas 9100 and a Selstrom.  Both say 23 degrees f is lowest temp to use them in.  This is in their respective booklets.  Best  bob
Reply:I didn't store my hood(Speedglas 9100x) outside, but I welded with it in single digit and below 0 temps and didn't have a problem with it..  I also had my fixed shade on stand by just in case I did.
Reply:Thanks To All Of You -The main thing is not to panic or get excited Bobcat 250, X-Treme 12VS,  MM211Meltabo, Milwaukee,Porter Cable,Dewalt,MakitaVictor O/A, Ingersoll-RandEvolution Rage2, 40 amp PlasmaLincoln 225 AC/DC
GMT+8, 2025-12-25 09:39 , Processed in 0.093491 second(s), 18 queries .
