Welding blades
发表于 2021-8-31 23:42:21 | 显示全部楼层 |阅读模式
This is how the pros do it:
Reply:Hey surf,I'm a pro & I didn't have to spend $100,000+ for a computer blade welder to get the same results. My HF blade welder was $99 when I bought it & the 250' rolls of blade were $56/ea.. I can make my blades for $1.55/ea. for my (2) bandsaws.Denny Attached ImagesComplete Welding/Machine/Fab. ShopMobile UnitFinally retired*Moderator*"A man's word is his honor...without honor there is nothing.""Words are like bullets.... Once they leave your muzzle, you cannot get them back."
Reply:That’s a nice stuff, Denny! Though, you shouldn’t compare it to theirs’ because they do heavy production of blades. And they need to secure the quality while time is being maximized. Don’t get me wrong. I would love to hear from you how you do it. How many blades you weld in a day or so.
Reply:sounds like it's personal use for him so I doubt he's doing multiple blades in a month, let alone a day.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:I seen on cl a blade welder think it was 50$ now ill have to look again it was on a band saw . Chit should have got it huh
Reply:You should’ve grabbed it. Do you weld blades too?
Reply:There have been any threads on welding blades.  Most argue that silver solder works better than a weld and is easier to get a good result with.  I bought some just for that.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Originally Posted by Drf255There have been any threads on welding blades.  Most argue that silver solder works better than a weld and is easier to get a good result with.  I bought some just for that.
Reply:sorry..duplicate postLast edited by surfside; 10-11-2012 at 09:20 AM.Reason: duplicate post
Reply:I made a jig and have TIG welded bandsaw blades.Load the blade,trim with a cut off blade,butt them together,.023 mig wire,.040 tungsten,temper with the Turbotorch,grind flush.....good to go.Then I learned the blade shop charges 3.00 to weld the blades.....no brainer for me.I know that I can save a blade on a weekend but no point when buying new blades,for me anywho.
Reply:Originally Posted by surfsideThen, how was the result?
Reply:Thanks, Drf!
GMT+8, 2025-12-25 07:49 , Processed in 0.092861 second(s), 18 queries .
