pickled and oiled a-36 steel for smoker
发表于 2021-8-31 23:42:20 | 显示全部楼层 |阅读模式
Does anyone know if building a smoker out of P&O A-36 steel would be safe?  I was thinking that if I clean it all with acetone and do a good burn in that that would be enough to get rid of the oil.  I don't want to make anyone sick, so I figured I should ask first. Thanks.Why buy it for $10 when you can build it yourself for $100.
Reply:Just like any other steel, just do a hot brn in it first to burn of all the oil.
Reply:X2 on the hot burn-in, or you could use a rosebud or one of those propane weed burners if you know someone with one.
Reply:Do the first round of cleaning with some heavy-duty alkaline cleaner."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Cool. Thanks for the info.  I called to get a quote on a 5'x10' sheet of 1/4" P&O plate and they said $338.  Is that a resonable price? I've never bought a full sheet of plate.Why buy it for $10 when you can build it yourself for $100.
Reply:Just buy hot rolled. Hot rolled steel is the same as P&O before it is acid washed (pickled) and oiled. Since you are just going to burn stuff in it it will develop a scale to it, so jst use hot rolled.
Reply:walker,   I was thinking about P&O because it is cheaper then hot rolled. (by over $100 a sheet.) I'm going to be building this for a guy I know and want to do it as cost effective as possible.  Luckily for me, I have a 13 year old son that wants to learn to work with metal, so I won't be doing any of the oil clean up. Why buy it for $10 when you can build it yourself for $100.
Reply:Originally Posted by walkerJust buy hot rolled. Hot rolled steel is the same as P&O before it is acid washed (pickled) and oiled. Since you are just going to burn stuff in it it will develop a scale to it, so jst use hot rolled.
GMT+8, 2025-12-25 07:57 , Processed in 0.086296 second(s), 18 queries .
