Torch Carts
发表于 2021-8-31 23:42:17 | 显示全部楼层 |阅读模式
I have seen a lot of welding carts on the site but I think that we should see what all of you have for your torches. I would like to see them if you are willing to post. Thanks in advance.KroekerMiller Trailblazer 302Miller Dial ArcMiller Suitcase 12RCVictor Torch
Reply:Here is mine. Had som round bar and a littl diamond plate and a couple of go kart slicks Attached Images
Reply:Hey Kroeker,Here's an aluminum torch cart I made. The wheels are from a scrapped wheelchair. Denny Attached ImagesComplete Welding/Machine/Fab. ShopMobile UnitFinally retired*Moderator*"A man's word is his honor...without honor there is nothing.""Words are like bullets.... Once they leave your muzzle, you cannot get them back."
Reply:sweet carts !!   love the slicks.  i want alum cart with slicksDaye
Reply:Sweet Carts. I made one. It is ok, but it gets the job done.Here is the link to it.http://weldingweb.com/vbb/showthread.php?t=49251We are on our way to being farmers! Our site is always under construction so check back often for updates.  http://www.philosophyfarmstyle.com/
Reply:Originally Posted by jdod85Here is mine. Had som round bar and a littl diamond plate and a couple of go kart slicks
Reply:Great Looking carts guys!Thanks again for posting.KroekerMiller Trailblazer 302Miller Dial ArcMiller Suitcase 12RCVictor Torch
Reply:Originally Posted by 7A749I have posted this numerous times on a few different boards.My apologies to those who have seen these before.
Reply:Better than mine.We are on our way to being farmers! Our site is always under construction so check back often for updates.  http://www.philosophyfarmstyle.com/
Reply:i don't see any with the OSHA mandated 30 min firewall.  while it isn't mandated on IN USE torch carts many job sites require it regardless.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:dualie-osha doesnt apply to hobbyists, and on jobs below a certain $$ size..this is my oa cart.. it sits in a shed now, i've moved my bottles hoses and  torches outside into a weatherproof rubbermaid garden shed , feels safer to have it outside the house in case a valve or fitting  decides its time to leak..i always had the unpleasant feeling that when i turned on the garage light a spark would ignite a crapload of acetylene.. now its outside in a plastic shed.. if i open the door and smelled gas, theres no metal to spark, just walk away..it's all 2 x 1/4 angle , plus 50 pounds of plate in the base for added stability...i made it too short and spliced 3" into the legs.. Attached Images
Reply:Here is my torch cart. I use a hand truck from Harbor freight.
Reply:Nice propane setup. I like the elevated propane jug to reduce bending over, and you got the hard wheels instead of the nasty pneumatic type that dry rot and go flat.
Reply:Originally Posted by brslkThat is an awesome cart.
Reply:7A749..      The cart that I built looks very very similar to yours.. Same tube, same design, right down to the tray that they sit on. ..Crazy!   Ill have to get a pick of mine tomorrow so you see what i mean..
Reply:Cool carts!MarkHammerhead RacingEdgewater Fl.  www.hammerhead1320.com
Reply:Well here is my torch cart built some time in 2000 or maybe 1999. I use a #50 roller chain to hold my bottles in place. I like the chain because it forms well to the bottles and never moves around. I pull the bottles into a pcs of channel.                                    Vernon Attached ImagesLast edited by 1969 Vernon; 01-29-2011 at 08:40 PM.Homemade Belt Sander "LINK"http://s795.photobucket.com/albums/y...Belt%20Sander/
Reply:[QUOTE=7A749;464794]I have posted this numerous times on a few different boards.My apologies to those who have seen these before. That is freaking nice!You have to learn the rules of the game. And then you have to play better than anyone else. Albert Einstein
GMT+8, 2025-12-25 08:05 , Processed in 0.105736 second(s), 19 queries .
