Another good guess?
发表于 2021-8-31 23:42:15 | 显示全部楼层 |阅读模式
We put this together the other day, but there were some issues with it not being true.  So I CNC plasma cut some end pieces for the round stock to run into, then I used a rose bud to heat the 5/8" cold roll round so it would stretch a little and hit evenly.. What isnt in the photos is another removable 2" round stock piece that rests at the end that is a little wider than the ram side.  One thing I noticed is that my phone picks up heat way better than the eye.  In one of the photos, you could not tell by looking at it that it was hot at all. Attached ImagesCommon sense in an uncommon degree is what the world calls wisdom.
Reply:I know what it's for (I'm not going to post the answer till some others get a chance to guess) though that's about the biggest one I've seen. I've made a few small ones years ago and my buddy just got through making some copies of the ones I made him back then. He's also got some larger ones nearly that big that we made back then.Millermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
Reply:very large cattle prod tongsMikeConstans Fides et IntegritasLincoln Weldanpower 150 ACAirco Aircomatic MIGet CAV II w/ spoolgunMillermatic 30a wirefeeder
Reply:No idea on what it is, but that "heat" is infrared that the camera sensor will pick up but our eyes wont.
Reply:Squeeze off for polyethelyne pipe??
Reply:You got it... They guys at the local dump have methane pipes running throughout and they pinch off the line to work on it.Common sense in an uncommon degree is what the world calls wisdom.
GMT+8, 2025-12-25 07:57 , Processed in 0.093051 second(s), 18 queries .
