It aint much but it works!
发表于 2021-8-31 23:42:15 | 显示全部楼层 |阅读模式
Well after the snow 2 weeks ago here in the south I found that the front end was too light on my latest garden tractor project. I took the 16 hp briggs out of this tractor and installed a 18 mag. Put in a tractor pulling clutch spring and kevlar clutch disk. It will lift the front end off the ground about 6 inches at idle in 3rd gear. So I brought home a pice of a roll cage from a forklift at work the fab guy had to modify for the customer. Turns out that it woks perfect for holding the 45lb suite case weights. I started with a mule drive that runs the deck and just welded the bars on. I tried to do things like bevel the fit ups as Ive seen so many of you guys do here. I now it not much compaired to what a lot of you post, but Im as green as grass when it comes to welding so I try and get in as much as I can on the weekends. Attached Images
GMT+8, 2025-12-25 07:57 , Processed in 0.064012 second(s), 18 queries .
