Welding Table Plans
发表于 2021-8-31 23:42:14 | 显示全部楼层 |阅读模式
I was searching for welding info and came across some info for a welding table that I thought might help people. I like the idea of the plasma/torch attachment. You can also download the plans in a pdf document. http://www.millerwelds.com/interests...welding-table/
Reply:I would suggest using expanded metal on the bottom shelf, firstly it keeps the weight down, secondly dust cant collect as easily, thirdly cost savings
Reply:I am very new to welding and taking a metal fabrication class. I would like to this or similar table as a class project. Approximately how much do you think materials would be for this?Thanks
Reply:A lot. New steel is $$$$. Try to find scrap as much as possible. I regularly go scrounge around the steel yards scraps pile, it's amazing what you can find sometimes. Course, everything will be too short likely, so you might have to cough up the money and buy new steel, but try to get everything else from the scrap bins. Or look on craigslist or go talk to local steel contractors.. you might be surprised how much scrap is just laying around looking for someone to pick it up. I just got 100 pounds of scrap for small projects for less than the 5' sch 40 pipe and the 5' 2"x1/2 stock I bought new. Plus, I found several punched and fabricated brackets in the scrap heap that will work perfect for my dozer project later on, and the 1 3/4 cold rolled pin.... all for scrap prices!
Reply:Not sure about all the cost, but I just purchased some 2"x2"x1/8" and it was $57.84 per stick.  The major cust will be the 3/8" top.  But the good side is an excellent welling table.Good luck!
Reply:and I agree with the expaned metal on the bottom.
Reply:I agree with the expanded metal.  I have a similar table with bedrails used as shelf supports and I threw some plywood down for a shelf, and it's gonna be a mess real soon.Hobart 125Words mean things
Reply:oops double postLast edited by oxygen454; 01-29-2011 at 10:23 PM.
Reply:x3 on the expanded metal unless you plan on stacking a lot of steel (weight) on there which makes the table hard to push around the shop. 4'x8' x3/8 at $1.10 a pound would cost $539.26. Square tubing... if you use 2"x2"x 1/8  this would cost you at $1.10 a pound,  per foot ... $3.37  (need approx 60') = $202.2Plus.... wheels               $35welding wire       $45welding gas        $50cutting disks       $50 (at $5 a zip disk)sanding/grinding disks  $16 ($2 a sanding disk)=$196Total (roughly) = $937.46If my math is right... Wow! thats quite a bit Last edited by oxygen454; 01-29-2011 at 10:24 PM.
Reply:Nothing is cheap anymore.
Reply:No kidding. The price of steel keeps rising... and fuel.
Reply:Originally Posted by oxygen454x3 on the expanded metal unless you plan on stacking a lot of steel (weight) on there which makes the table hard to push around the shop. 4'x8' x3/8 at $1.10 a pound would cost $539.26. Square tubing... if you use 2"x2"x 1/8  this would cost you at $1.10 a pound,  per foot ... $3.37  (need approx 60') = $202.2Plus.... wheels               $35welding wire       $45welding gas        $50cutting disks       $50 (at $5 a zip disk)sanding/grinding disks  $16 ($2 a sanding disk)=$196Total (roughly) = $937.46If my math is right... Wow! thats quite a bit
Reply:Well as far as i know you should have to use expaned metal on the bottom.CHEAP DATA RECOVERY
Reply:Originally Posted by BoostinjdmWhat hole are you pullin' your numbers out of?  You'll need four good wheels that might cost $35 each.$45 will buy me over 20 lbs of wire.  I doubt there is much over 5 lbs in that table.$50 in gas?  prolly closer to $8.  I can fill my 125 bottle for about $40.Zip disks only cost me $1.26 or there abouts.Sanding disks are more like $5-$8 each.
Reply:Cheaper cutting disks can also be purchased ($1.39), although I prefer Zip Cut...Cheaper disks.
Reply:The cost of everything sucks now days, but being able to say I built it and it is built better than what you can buy is priceless.I would put some holes or slots in the top for different jigs or clamps to slide into.We are on our way to being farmers! Our site is always under construction so check back often for updates.  http://www.philosophyfarmstyle.com/
Reply:Originally Posted by yarmishThank you for pricing that out...I will submit the steel list to a local supplier and see what it cost in US dollars. All of the consumables are free of charge in the class. Maybe i can down size the table a bit to keep the cost around $500
GMT+8, 2025-12-25 07:49 , Processed in 0.068791 second(s), 18 queries .
