Repair Plow Moldboard
发表于 2021-8-31 23:42:09 | 显示全部楼层 |阅读模式
Has anyone repaired a broken plow moldboard?Friend of mine brought me a moldboard that he broke when he backed into a ditch.Pictures to follow.Be thankful we're not getting all the government we're paying for
Reply:Originally Posted by RVPHas anyone repaired a broken plow moldboard?Friend of mine brought me a moldboard that he broke when he backed into a ditch.Pictures to follow.
Reply:That's exactly what he means.  A moldboard is an earth-turning plow, not a pushing-stuff blade.(That said, you can get a rear blade attachment for a tractor that looks just like a snowplow, but mounted on the 3-point hitch.)
Reply:Really?   Do a google search on the following term and then contact companies like Meyer, Boss, Henderson, etc. and tell them they don't know what they are building, or talking about."snow plow moldboard" Originally Posted by OkieDaveThat's exactly what he means.  A moldboard is an earth-turning plow, not a pushing-stuff blade.(That said, you can get a rear blade attachment for a tractor that looks just like a snowplow, but mounted on the 3-point hitch.)
Reply:Along with every major manufacturer out there....Also, to the O.P., check out letstalksnow and plowsite forums, both have had plow rebuilds with pics, over the years... Originally Posted by 7A749Boss refers to the skin section of the blade as a mold board (just for kicks, I priced the skin out before I did the last plow job I had come in) hence my understanding of the terminology. Delwas posted as I was typing Again, without seeing pics, kinda hard to offer a fix for it.
Reply:Me too!  For years I used an F-350 with a Diamond.  Every year I was welding something or other...  Current setup is a John Deere with FEL, and either the back blade or rear blower.  Much more durable, but unfortunatly no cab, ah well, someday  Originally Posted by 7A749Yeah. Up till I talked to Boss, I only knew it as a "skin".Whatever the case, I really hate doing plow repairs....
Reply:To those of you who do plow repairs. All I can say is thank you. as it allows me access to the mountains I love so much. Granted out here you only see actual plows on DOT vehicles.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Well, I appear to have been schooled.  Guess I should shut up and do a little more research before I post.  Mea culpa.
Reply:When I started on hiway construction long ago the old timers called a dozer or the blade on a grader a moldboard. I still do. Just before I retired I was talking about the moldboard on the D9-L I was running and a youngster asked me what I was referring to. I said, pointing at the dozer, "that's a moldboard".                                MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
GMT+8, 2025-12-25 07:49 , Processed in 0.098182 second(s), 18 queries .
