10 common Tig problems
发表于 2021-8-31 23:42:06 | 显示全部楼层 |阅读模式
Ten Common Tig problemshttp://www.millerwelds.com/resources...-guide-graphicEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Nice info find Ed.  Just so that you know that at least -someone- looked at your posting.    The best laid schemes ... Gang oft agley ...
Reply:thanks ,  good oneDaye
Reply:is all you do is quote peoplewhat about a wandering arc
Reply:Originally Posted by ed macis all you do is quote peoplewhat about a wandering arc
Reply:The link IS there!DaveHobby welder for 40 years.Miller Thunderbolt ArcMillermatic 180 MIG
Reply:Great find! Thanks, though I knew/found out most problems and causes it was a good to see it again in a nutshell.Now wait for part II: the not-so-common TIG problems, might be a start of a large troubleshooting guide.
GMT+8, 2025-12-25 09:17 , Processed in 0.093986 second(s), 18 queries .
