my new TIG rig and work been doing
发表于 2021-8-31 23:42:05 | 显示全部楼层 |阅读模式
Sorry been away a while... Work, sweat and learning TIGMy new rig Lorch V30 with combination cooler by Kobeweld and a turn key project for new oxygen plant.Will post some pic later... Can't upload from Blackberry for some unkown reason.Unit in my fab shop dept:my good hand and team that trust me...A lone welder make art... a village full of welder make Miracles...
Reply:here some pic upload hope hear old friends comment and corrections... Attached ImagesUnit in my fab shop dept:my good hand and team that trust me...A lone welder make art... a village full of welder make Miracles...
Reply:here is the rig for TIG... combo of Chinese, Japan and European stuff... I would opt for Lincoln or Miller that the rep here for these famous brand is not really going around... Attached ImagesUnit in my fab shop dept:my good hand and team that trust me...A lone welder make art... a village full of welder make Miracles...
Reply:Hi Mandau, I always enjoy pictures from your country. Nice bead too, aluminum? By the way, your concrete guy needs steel toes for his sandals.
Reply:you can pick up item from the wet cement floor with ye sandal feet than using a steel toes... ah well... field worker use boots while the cement guys get wet rubber boots...thanks for the comment... Lorent.Unit in my fab shop dept:my good hand and team that trust me...A lone welder make art... a village full of welder make Miracles...
Reply:Hey,I'm new here and have just seen your post about the Lorch machine, I have the V30 AC/DC with the combined water cooler, a lot less portable but ok if your just in the work shop. Had my machine for about 2 years now, amazing arc stability, actually starts an arc at 3 amps, even on larger tungstens its still stable if theyar razor sharp down at the low end. I dont know why I haven't seen more people using them?!Runs better than the Miller DX350 I was using at my last contract!I use my rig for 0.9mm 4130 ans lots of thin staneless, mostly cycle frames etcAny one else have a lorch, what are your views on them?JDLast edited by KingdomBikes; 12-08-2009 at 02:17 PM.
GMT+8, 2025-12-25 09:23 , Processed in 0.093369 second(s), 18 queries .
