what are the dwell time settings used for?
发表于 2021-8-31 23:42:05 | 显示全部楼层 |阅读模式
Hello,  I have always stick welded.  But now I would like to learn to mig weld.  I have not problems stick welding anything in any position.I have a 380  volt single phase mig welder. It has a dial for voltage 1 - 6It has a dial for dwell timeit has a dial for wire feed speedit has a dial for weld timeit has a dial for  manual auto stitch spotvoltage I understandwire speed I understandDwell time settings no clueweld time settings no cluemanual auto stitch spot I understand.straight Argon gas bottle on the unit.I don't know why I even plugged this thing in but I did so now I must learn how to use it correctly.I love to weld with stick welder!
Reply:The answer is on the right hand page about halfway down. You will have to read the paragraph[ how to use a basic spot welder + spot weld testing] a few times to get it to sink in.http://books.google.com/books?id=B4U...elding&f=false
Reply:so is the dwell time and weld time settings for spot or stitch welding only?the link in your post was for me to buy a book.  There was no information available.
Reply:Yes, dwell and weld time are the spot/stitch controls.  Turn those off to do regular, continuous mig welding.  Only 3 settings you need to control for regular mig is voltage, wire speed and gas flow, if using solid wire and gas.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:thank you for the answer.  I just have to figure out what I should set the gas at.  I would like to use it to weld some square tube 1/8 inch wall thickness.  Would I be better off to get a bottle of 75/25 for mild steel welding?
Reply:Originally Posted by burnandreturnso is the dwell time and weld time settings for spot or stitch welding only?the link in your post was for me to buy a book.  There was no information available.
Reply:I’m puzzled; I have no problems seeing the book and page with the information. I can page through the book chapter by chapter.This how it was done.Googled WHAT IS DWELL TIME IN WELDINGThe link title is. WELDER’S HANDBOOK: A GUIDE TO PLASMA CUTTING, OXYACETYLENE, AEC,..,- GOOGLE BOOKS RESULTS.BY RICHARD FINCH – 2007 TRANSPORTATION – 153 PAGESISBN = 155788133The info is on page 133 in chapter 15
Reply:Originally Posted by burnandreturnthank you for the answer.  I just have to figure out what I should set the gas at.  I would like to use it to weld some square tube 1/8 inch wall thickness.  Would I be better off to get a bottle of 75/25 for mild steel welding?
GMT+8, 2025-12-25 09:18 , Processed in 0.089741 second(s), 18 queries .
