How much do you think this ring gear weighs?
发表于 2021-8-31 23:42:01 | 显示全部楼层 |阅读模式
I was asked about removing this ring gear from the building it is in, just trying to make a guesstimate on how much it weighs.The picture is not the best because it is a picture of a picture but you can get the idea from it. I haven't seen it yet but the info given to me was as follows.The gear stands 101 1/2" tall, 5 3/4" wide and from the edge of the teeth to the inside edge is 3 3/4 thick".  Any guesses? Attached ImagesI am what I am, Deal with it!If necessity is the Mother of Invention, I must be the Father of Desperation!
Reply:I'm guessing it weighs approximately alot...(Retired) Professional firefighter, amateur everything else I try to do...Oh yeah:  Go Big Red!   (You know: one of the 12 members of the Big 10 cuz we left the 10 members of the Big 12...)
Reply:Originally Posted by strube1369I'm guessing it weighs approximately alot...
Reply:212 pounds.Let's start a pool!Buy American, or don't whine when you end up on the bread line.
Reply:950 lbs give or take.
Reply:I'm going to say 1150 lbs.You get what you put in and people get what they deserve...
Reply:2000 #  + or - 5%
Reply:1 dollar bob lol...... 1800
Reply:Originally Posted by denrep2000 #  + or - 5%
Reply:2336lbs
Reply:What is the composition of the ring?Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:Assuming that the cut gears have a 'real' thickness of 3.25" vs the measured 3.75", Use a diameter of 101" (x 3.14) to get a length (circumference) of ~317",   then 317 x 5.75" x 3.25 = 5924 cu. in.    and 5924 cu. in.  x  0.28 lb/ cu. in. = 1659 pounds,this assuming further that it's steel as it appears to be..Last edited by Oldiron2; 01-28-2011 at 11:03 PM.Reason: added comma......
Reply:20oz per lb.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:I had assumed "edge of the teeth" to mean the tooth's root.
Reply:Originally Posted by denrepI had assumed "edge of the teeth" to mean the tooth's root.
Reply:1940 lbs. minu the cutouts for teeth."The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt
Reply:1876 lbs minus the cutouts for the teeth.
Reply:I calculated the area of the entire circle (3.1415 X 50.75 X 50.75 = 8091.4)I then calculated the area of the center of the ring (3.1415 X 47 x 47 = 6939.8)I then subtracted the center of the ring from the entire circle from (8091.4 – 6939.8 = 1151.6)I then multiplied the area of the ring by the thickness (1151.6 X 5.75 = 6621.7 cu in) I then multiplied cu in of the ring (6621.7 X .29 = 1920.3 lbs)I was not able to calculate the weight of the voids between the teeth because you did not supply tooth geometry this needs to be subtracted from the above weight to get the correct weight
Reply:The question is...can you cut it?--------------------------------------------------------------www.becmotors.nlyup, I quit welding.. joined welder anonymous
Reply:d=101" so c= 26.44'5.75" x 3.75"= .479' x.3125'=.148sf ignoring tooth profile x26.4lf=3.95cf assuming steel @ 490#/cf=1936 pounds.
Reply:Just a thought for you fellows who need to figure the tooth cutouts, try figuring a ring with a ID from the root of the teeth and the current OD and half that amount which would account for the cutouts and add that to the remainer of the ring. You would need to know the depth of the teeth to do this. Have fun.
Reply:Originally Posted by trapperjohnJust a thought for you fellows who need to figure the tooth cutouts, try figuring a ring with a ID from the root of the teeth and the current OD and half that amount which would account for the cutouts and add that to the remainer of the ring. You would need to know the depth of the teeth to do this. Have fun.
Reply:1630 lbs
Reply:Wife sez: " One thousand, two hundred and ten pounds. I can tell just by looking at it."I say: Does not matter how much it weighs. Four strong guys. Set it on the floor. Roll out without tipping or going too fast. Flop onto trailer deck, and move around with bars till happy.Carry on.
Reply:1,120Lbs2,740 LBS  Give or take 100 LBS         VernonHomemade Belt Sander "LINK"http://s795.photobucket.com/albums/y...Belt%20Sander/
Reply:850 Kilograms Miller Diversion 165120 amp Buzz BoxVictor Oxy/Ace Oxy/LPGSmith "Little" Oxy/LPGHypertherm Powermax 30Lot's of Misc. tools n' crap....
Reply:Originally Posted by jman850  Kilograms
Reply:Originally Posted by Oldiron2I finally can't resisting asking you what the situation is with this gear. Was it in for repair, for inspection, what was just done to it by that device shown, was it removed from some equipment there, what kind of machinery does it go with, how did you get involved in moving it.......I assume they don't intend for it to be cut up and removed, as I believe someone above suggested.
Reply:How the heck did they get this stuff in the building? lol
Reply:#1929 less the teeth.= #1594 is my guessG
Reply:Here is what I came up with.We know i2 = -1 , now the successive powers of i are  (i) i1 = i                   (ii) i2 = i X i = -1              (iii) i3 = i X i X i = -1 X i = -i                      (iv) i4 = (i2)2 = (-1)2 = 1  (v) i-1 = -i                (vi) i-2 =1/( i X i) = -1         (vii) i-3 =1/( i X i X i) = i                           (viii) i-4 = 1/ (i)4 = 1My guess is: 2040.02222225555555555555555555555555give or take .02-.025I went to a publik skool---No good deed goes unpunished---
Reply:Originally Posted by mebuildit. . .give or take .02-.025I went to a publik skool
Reply:I never seen any mention of it's makeup......So i assume it is made of plastic , china import and about 68lb and 12 oz.
Reply:AAA.... where do i collect my prize...???
Reply:Originally Posted by 1awert1I never seen any mention of it's makeup......So i assume it is made of plastic , china import and about 68lb and 12 oz.
Reply:Originally Posted by denrepSloppy "new" math.
Reply:windmills would use an internal ring gear to slew the nacelle into the wind.   basically rotate the dog house at the top of the pole to face into the wind.   Like the slewing gear on an excavator or a crane but i doubt this is from one of those.it looks like they were trying to magnaflux it with that setup.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:ill give ya a cats *** for it if u deliver ! lol i wanna make a mail box mount out of it ?I forgot how to change this.
Reply:If you got enough VIAGRA, you can DO IT.Miller thunderbolt 250Decastar 135ERecovering tool-o-holic ESAB OAI have been interested or involved in Electrical, Fire Alarm, Auto, Marine, Welding, Electronics ETC to name a just a few. So YES you can own too many tools.
Reply:Would make a helluva stand base for yer grinder.
Reply:Rear gears for the REALLY short trackDynasty200DX w/coolmate1MM210MM VintageESAB miniarc161ltsLincoln AC225Victor O/A, Smith AW1ACutmaster 81IR 2475N7.5FPRage3Jancy USA1019" SBAEAD-200LE
Reply:It cant be over 1200-1500 lbs. How I know?? I work for a scraper right now.  I would cut that BIG S.O.B. into 3 ft long sticks.....Of course I don't look busy.....I did it right the first time!
GMT+8, 2025-12-25 07:49 , Processed in 0.094744 second(s), 18 queries .
