New Shop Table
发表于 2021-8-31 23:42:00 | 显示全部楼层 |阅读模式
I have been meaning to build a new larger work table for a while.  We have (2) 5'x10s and (1) 4'x10.  This table is 5' x 20'.  The perimeter frame is W10x33 and the interior runners are C6x8.2 spaced at roughly 30" O.C.  The legs are 6"x4"x3/8" and the connecting pipes are 4" std.  The 45 kickers are 3"x3"x1/4".  I used 7/8" grade 5 all thread and 7/8" heavy hex nuts for the levelers.  The top is made out of (2) 5'x10' pieces of 1/2" PL seamed in the middle with a slight bevel and ground flat.  Now keep in mind, I didnt spend a dollar on this table.  Aside from what I consumed welding and cutting.  So there are reasons why it is what it is.  Overall weight is around 4K lbs.   I still have to clean it and wipe with oil.  BrandonLots of toys.
Reply:That's a Table!   How high of thr floor?Nice BIG work.DayePound to fit, paint to match
Reply:Its 37.25" off the floor.   The oldest table in the shop is that height and we have made them all the same so you can put them together and heights match.Lots of toys.
Reply:damn that's one big table._______________________OF COURSE I DON'T LOOK BUSY... I DID IT RIGHT THE FIRST TIME
Reply:Sweet table!
Reply:@Brandon75173 Nice table. @Mick120 You got some more pics of the jigs you made for that table?We are on our way to being farmers! Our site is always under construction so check back often for updates.  http://www.philosophyfarmstyle.com/
Reply:Very nice looking table Brandon, the surface area must be a dream to work with.Gordhttp://gordsgarage.wordpress.com/
Reply:That is a thing of beauty.A bit large for my 2.5 car garage though.You get what you put in and people get what they deserve...
Reply:Thanks for the compliments.  Its nice to have enough leftover material to build something like this we really need.  Thats why patience pays off.Lots of toys.
Reply:Dang nice table.What is the size of the levelers on the feet? 5/8ths?What would you say that beast weighs?Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Really nice looking, just have a question. what size threaded rod for the levelers and do you think the rod will handle any lateral movement?..how much does that table weigh?..thanxs
Reply:Originally Posted by brandon75173 I used 7/8" grade 5 all thread and 7/8" heavy hex nuts for the levelers.  The top is made out of (2) 5'x10' pieces of 1/2" PL seamed in the middle with a slight bevel and ground flat.  Now keep in mind, I didnt spend a dollar on this table.  Aside from what I consumed welding and cutting.  So there are reasons why it is what it is.  Overall weight is around 4K lbs.   I still have to clean it and wipe ]
Reply:Brandon, thanks for pointing out I don't read worth a dang. lol. I just get all excited when I see the pretty pictures. You will have to let us know if those ever fail. I don't have a spec book to see what that thread would hold. I have a tendency to over engineer. Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:You could land Navy planes on that thing!"These instructions are at our present level ofknowledge. Legal requirements do not exist.Technical issues subject to change."_________________________________________Lincoln MIG PAK 180Lincoln AC-225
Reply:Originally Posted by Robert HallBrandon, thanks for pointing out I don't read worth a dang. lol. I just get all excited when I see the pretty pictures. You will have to let us know if those ever fail. I don't have a spec book to see what that thread would hold. I have a tendency to over engineer.
Reply:Well, if your sick obsession ever lands you anywhere near me, look me up. Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:HOLY SHINTO!!!!!! That's a table!!!!!200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack.
Reply:@Brandon75173I agree about the patience.@Mick120  Thanx for the pics. I am assuming you bolt the jigs in place? Got any pics of your work set up in those jigs?I'm in process of building a big, but light duty fabrication table. Around 4foot X 9foot X 3/16 thick top. I'll be mocking up and fabing light steel on this one. Also use it to roll 4wheelers and riding mowers up on it..... That means I have to build some custom ramps for it also.Only other table I currently have.... Well everybody gets givin me the same excuse. Of course it is on fire it is wood.We are on our way to being farmers! Our site is always under construction so check back often for updates.  http://www.philosophyfarmstyle.com/
GMT+8, 2025-12-25 07:57 , Processed in 0.091992 second(s), 18 queries .
