Blue star 2E make over
发表于 2021-8-31 23:42:00 | 显示全部楼层 |阅读模式
frist of all , I would like to say thanks to duaneb55 (A.K.A. THE MAN)  for helping me fix this old girl.After getting it, to weld again.  I sandblasted the sheet metal and painted it, with ford blue tractor paint.  I read somewhere that suppose to be the right color.  Close, maybe a little light. Made a new cable holder / handle.  Cleaned everything up. new fuel lines, fuel filter and a gas shut off valve.fab up an alum. d-plate battery cover.  Got a new face plate and sticker kit. I had to make new gas tank straps. The old ones,  I think they fell off the bench outside while sandblasting, and I forgot about them.  Well it snowed, I'll find them this spring with the lawn mower I should change the pizza cutter tires out.heres some before and after picturesDaye Attached ImagesPound to fit, paint to match
Reply:AWESOME JOB!  Looks great! Judy saw it and said "Wow!  Ain't she proud!"Excellent!MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:amazing job man!_______________________OF COURSE I DON'T LOOK BUSY... I DID IT RIGHT THE FIRST TIME
Reply:It has lost its character.
Reply:Great workmanship!!!AWS certified welding inspectorAWS certified welder
Reply:Nice work Daye, well done on the restoration. The power of blue lives on!Gordhttp://gordsgarage.wordpress.com/
Reply:That's awsome! Amazing transformation.  Bet you are one proud owner. --Wintermute"No man's knowledge here can go beyond his experience." - John Lockewww.improvised-engineering.comManufacturer Agnostic:Blood----------Sweat---------Tears----|------------------|----------------|----Lincoln Red, Miller Blue, Esab Yellow
GMT+8, 2025-12-25 07:49 , Processed in 0.096448 second(s), 18 queries .
