Plasma circle burner
发表于 2021-8-31 23:41:59 | 显示全部楼层 |阅读模式
Well I have built a circle burner for my plasma torch. I all ready made one for my oxygen/acetylene Torch and really like it so I made this one. I used a carriage bolt to hold the center pin. I only need a 1/2" wrench to change the adjustment. I used a split set Collar to hold it to the torch. Works real nice. Well here's the pictures. Vernon Attached ImagesHomemade Belt Sander "LINK"http://s795.photobucket.com/albums/y...Belt%20Sander/
Reply:That's f--king awsome!   the 1st thing, I do tomarrow , is make one of these.nice job!   cutmaster?DayePound to fit, paint to match
Reply:Originally Posted by tigmuskyThat's f--king awsome!   the 1st thing, I do tomarrow , is make one of these.nice job!   cutmaster?Daye
Reply:Very nice.  I think this is the cleanest, neatest one i have seen.  Thanks for putting the pics up.  I suspect this will inspire alot of us!(Retired) Professional firefighter, amateur everything else I try to do...Oh yeah:  Go Big Red!   (You know: one of the 12 members of the Big 10 cuz we left the 10 members of the Big 12...)
Reply:How do you get the slot cut out going down the middle?  It is so perfect and straight.
Reply:I bet he has a mill or a lathe with a milling attachment.MarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
Reply:The Plasma circle burn parts where made with a milling machine than I made it shorter and welded the end on it. It was about 14 long at first. I thought it was a bit to long so I cut it.    * With a milling machine the whole project only takes about 2 hours or so *.        Vernon Attached ImagesHomemade Belt Sander "LINK"http://s795.photobucket.com/albums/y...Belt%20Sander/
Reply:Very nice!! Just curious how does the center point stay secured to the piece you are cutting? Do you drill a small hole for it to rest/sit in, or something else?- RyanLincoln Weld-Pak 140HDHypertherm Powermax 30HF 4x6 bandsawHF 21gal compressorCraftsman Commercial drill press4.5" Craftsman Professional angle grinder4.5" HF angle grinderOld benchtop table saw with a cutoff wheel and sawzall
Reply:Originally Posted by ryanPSDVery nice!! Just curious how does the center point stay secured to the piece you are cutting? Do you drill a small hole for it to rest/sit in, or something else?
Reply:Originally Posted by tackitNice job Vernon.     I bought one when I bought my plasma machine, it comes with a few attachments... mine has a magnetic base like in the video below....never used it yet though. Short video down at the bottom of the page of a HTP Plasma circle cutter in action.http://www.htpweld.com/products/plasma_cutters/400.html
Reply:Originally Posted by 1969 VernonI use a center punch to mark the center of the cut. Doesn't take much to hold it there.                                    Thank you Vernon
Reply:Originally Posted by jmanVery nice!I'm Curious also about something...  Does it 'teeter-totter' on you when you try and cut?  It looks to me like it would do that without a wheel on it...  Perhaps it just requires a bit of practice to use?Cheers,
Reply:A circle cutter is my next must do shop project !
Reply:Does the split collar have a bearing or does it clamp tight to the plasma torch tip.
Reply:Originally Posted by JRobAckerDoes the split collar have a bearing or does it clamp tight to the plasma torch tip.
Reply:nice
GMT+8, 2025-12-25 09:17 , Processed in 0.070571 second(s), 18 queries .
