Mapp Gas Brazing
发表于 2021-8-31 23:41:53 | 显示全部楼层 |阅读模式
Just wondering what materials I can use other than safety silver 45 or 56 to braze with a mapp torch? I am brazing 3/16 brake line for craft projects. Any ideas?Thanks,-Gary
Reply:You might find it easier to look for a hotter torch for this. An air acetylene torch would work, but one of the small jewelers OA torches would be a better choice. With the micro OA rig you would have a lot more heat, and finer precision. One of the small "aircraft" torches would also work. For something like this you wouldn't need a big set of cylinders. a small MC acet cylinder and a small O2 cyl like come in the Depot kits would work. That or the B size acet cylinders plumbers usually use with the air acet sets..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Regular bronze brazing rod would be cheaper."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Originally Posted by OldendumRegular bronze brazing rod would be cheaper.
Reply:You can with a swirl flame, but you will use a ridiculous amount of gas and time getting it to just barely hot enough.
GMT+8, 2025-12-25 11:21 , Processed in 0.091272 second(s), 18 queries .
