do i need a Inverter Generator for welding or can any generator be used ?
发表于 2021-8-31 23:41:53 | 显示全部楼层 |阅读模式
Can i use any type of generator to run my tig welder off of. Does it need to be on of the nicer Inverter Generator  so the volts dont change much ?If i had to do a small repair  can i run a miller 200 dx off a honda EU2000i inverter generator?
Reply:millers site has the specs and requirements for generator use on that machineMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:Originally Posted by Bigrich954rrCan i use any type of generator to run my tig welder off of. Does it need to be on of the nicer Inverter Generator  so the volts dont change much ?If i had to do a small repair  can i run a miller 200 dx off a honda EU2000i inverter generator?
Reply:Originally Posted by Broccoli1Doubtful the 2000EU will run the Dynasty 200 dx.It wouldn't run my Passport- I had to parallel 2 of the Honda 2000eu.
Reply:Originally Posted by mauricio_daniel_62Hi Broccoli1,This sounds interesting. Could you explain how do you do to run 2 generators in parallel, i would like to implement this but I dont know how to run attached the 2 generators in phase.Thanks in advance for your comments
Reply:Originally Posted by Broccoli1THEY NEED TO BE INVERTER GENERATORS.The Honda inverter  series can be paralleled quite easily by just using 2 banana pin cables between the 2 generators.But the Inverter generators are not cheap- each 2000watt is $1,000.00http://powerequipment.honda.com/gene...lel-capability
Reply:Originally Posted by WeldingWookiemillers site has the specs and requirements for generator use on that machine
Reply:It doesn't need to be an inverter. However if you are running an inverter machine off of it, you need to scope it to be sure it is clean power. Miller bobcats are known for extremely clean power and are not inverter generators.
GMT+8, 2025-12-25 07:49 , Processed in 0.094000 second(s), 18 queries .
