P&H Welder
发表于 2021-8-31 23:41:50 | 显示全部楼层 |阅读模式
I have a P&H welder, model #DAR300HFGW (DARHF). Its an ACDC high frequency welder.My question is, does anybody know how to set this grandpa up for aluminum tigging? I know I need straight Argon and pure tungsten, but Im hung on the settings for the welder.My welder is really old, I think roughly late 50's. Its huge and green...I nicknamed it the HULK lol.Any advice would be great guys Thanks a millDJ
Reply:Originally Posted by DJ420aI have a P&H welder, model #DAR300HFGW (DARHF). Its an ACDC high frequency welder.My question is, does anybody know how to set this grandpa up for aluminum tigging? I know I need straight Argon and pure tungsten, but Im hung on the settings for the welder. . . .
Reply:Haha i was gonna chime in but i haven't picked up the machine yet! Hopefully I'll get it by the end of the week, and i'll have a little more info (and pics) on these machines
Reply:Originally Posted by denrepWelcome DJ420a  Select AC and... Well what other bells and whistles on this beauty?Did you check in at the P&H club yet: http://weldingweb.com/vbb/showthread.php?p=295580Good Luck
Reply:Here are some pics Attached Images
Reply:more.... Attached Images
Reply:So with these pics, can anyone chime in and kinda give me a tutorial on how to setup the "HULK" for aluminum tigging?Thanks guys
Reply:Remote Output Control - Panel Control (no foot pedal), Remote Control (w/ foot pedal)Soft Start - Operative (thin material), Inoperative (thicker material) OR your choice based on your preference.  If in doubt - OperativeInert Gas Arc WeldingHigh Frequency - ContinuousHigh Frequency Control Rheostats - mid travel for nowSelector Switch - ACRange Selector - based on material thickness, can't see the numbers so start out on Medium RangeCurrent Control (Increase) - set accordingly based on material thickness and heat requiredArgon regulator - 20-25cfhThat should get you started and you'll have to adjust the Range and Current Control based on how much heat is needed.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Duaneb55 - You forgot to mention jamming the broom handle against the circuit breaker. DJ420a - Alright, let's see this baby run! Good LuckLast edited by denrep; 07-08-2009 at 02:00 PM.
Reply:Thanks a mill, you guys rock!!!I'll post pics of what I'm doing, when its done.Ive been tigging and stick welding black steel and SS for the past 5 years with this machine.......I love it lolThanks again guys
Reply:Originally Posted by denrepDuaneb55 - You forgot to mention jamming the broom handle against the circuit breaker.
Reply:Originally Posted by duaneb55Remote Output Control - Panel Control (no foot pedal), Remote Control (w/ foot pedal)Soft Start - Operative (thin material), Inoperative (thicker material) OR your choice based on your preference.  If in doubt - OperativeInert Gas Arc WeldingHigh Frequency - ContinuousHigh Frequency Control Rheostats - mid travel for nowSelector Switch - ACRange Selector - based on material thickness, can't see the numbers so start out on Medium RangeCurrent Control (Increase) - set accordingly based on material thickness and heat requiredArgon regulator - 20-25cfhThat should get you started and you'll have to adjust the Range and Current Control based on how much heat is needed.
Reply:Is your foot pedal plugged in? In AC mode? Does the HF kick on in "inert gas arc"?I dont think the gas opens without being in "inert gas arc" modeMy machine wouldn't work in "inert gas arc" without the foot pedal plugs in the machine, even in panel select mode. Originally Posted by DJ420aduaneb55, I set everything too your specs, but the welder will not let make an arc. I noticed if I change the "inert gas arc" switch to "metallic" it will make an arc. Problem is with this setting, it seems like its only blowing the aluminum out of the way, sorta make a "valley" in the aluminum plating.Any words of wisdom?
GMT+8, 2025-12-25 07:49 , Processed in 0.067602 second(s), 18 queries .
