first project
发表于 2021-8-31 23:41:47 | 显示全部楼层 |阅读模式
So I have been lurking around reading as much as I can. I have pissed the wife off because I will read the forum for a few hours at a time. So I got to finally got to the scrap yard and got quite a bit of steel for the welding cart and welding table. Here are a few pics of the build. It is made from 1 inch square tubing can't remember the gauge. The machine is a Lincoln 180c and straight co2. Sorry for the blurry they are with a cell phone and the angle is bad from the camera on the weld
Reply:Nice cart. Is that bottle of bubbly in the background for emergencies or success?Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:No its actually only sparkling cider got it after my first solo from flight school i was under age at the time (10 years ago) so i got that instead of champagne.
Reply:looks good    just remeber....   a happy wife is a happy life!!DayePound to fit, paint to match
Reply:looks good, i would add some angle iron or something to secure that welder to the cart better
Reply:The welders feet are a snug fit between rails its not going any where. The happy wife happy life is the truth she actually wanted to help and she did some grinding while I cut and welded even have a picture to prove it.
Reply:Originally Posted by 4x4RickThe welders feet are a snug fit between rails its not going any where. The happy wife happy life is the truth she actually wanted to help and she did some grinding while I cut and welded even have a picture to prove it.
Reply:Cool that she joined in! Next project should be a surprise for her!!! That'll be good for some points!200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack.
Reply:Rick, I strongly suspect your Power MIG 180 is identical to my MIG PAK 180.  I like that design, what are the dimensions of your cart?  Did you do anything to secure it to the cart?"These instructions are at our present level ofknowledge. Legal requirements do not exist.Technical issues subject to change."_________________________________________Lincoln MIG PAK 180Lincoln AC-225
Reply:Hardware the 180c is the same pretty much identical other then has all aluminum wire feed block and is not a tapped machine. the dimensions on the cart are31 1/4 " length10 1/2' wide just enough so that the feet fit tightly in the machine.16'' tall without wheels 20 with wheelsthe handle is 31 1/2 off the ground cut at a 25 degree angle
Reply:sweetness on the wifey jumping in. My ol lady made a few puddles a few weeks ago, a little gun shy, but she looked like she felt pretty accomplished afterwards
Reply:Originally Posted by 4x4RickHardware the 180c is the same pretty much identical other then has all aluminum wire feed block and is not a tapped machine. the dimensions on the cart are31 1/4 " length10 1/2' wide just enough so that the feet fit tightly in the machine.16'' tall without wheels 20 with wheelsthe handle is 31 1/2 off the ground cut at a 25 degree angle
Reply:Originally Posted by tigmuskyThat-A- boyNICE  Daye
Reply:I would encourage a face shield when grinding.  if you see some of the pix of oh oh's -  they aint pretty-- fredLincoln 180C MIG
Reply:X2: On a full face shield when grinding.  http://www.ncbi.nlm.nih.gov/pubmed/18215305Stay away from Harbor Fright wheels.
Reply:Hardware tapped means you have a machine that only allows 6 voltage settings. A through F vs a continuous machine allows for infinite voltage adjustments within those rangesGood call on face mask will be getting a couple
Reply:BTW: Nice cart...
GMT+8, 2025-12-25 09:24 , Processed in 0.104494 second(s), 18 queries .
