Best method for cutting 9 chrome steel
发表于 2021-8-31 23:41:44 | 显示全部楼层 |阅读模式
Need to split 10" dia. Tees...is plasma the best method.
Reply:Well, it's quicker than a zip disc on a side grinder but you will have some clean up to do.orA gas powered friction saw http://www.stihlusa.com/products/cut...chines/ts500i/How many are you splitting and how quick do you need it done?and..........How much you want to spend (each)?Lincoln SA200's... at least 15 - 20. They come and go. Growing partial to the "Short Hoods" in my old age. Last count on Short Hoods was 13 in possession.
Reply:Plasma cutting is not bad though but if you  like precise cutting without cleaning up a lot, less grinding and cleaner cut ,you can go for band saw cutting .
GMT+8, 2025-12-25 09:18 , Processed in 0.074708 second(s), 18 queries .
