Techniweld Rods
发表于 2021-8-31 23:41:42 | 显示全部楼层 |阅读模式
Anybody got any input on what number these rods might begot them at lws only 1/16 they had - ther blue in color - no info at techniweld web site on this rod - 1# tube - Thanks Attached ImagesThe main thing is not to panic or get excited Bobcat 250, X-Treme 12VS,  MM211Meltabo, Milwaukee,Porter Cable,Dewalt,MakitaVictor O/A, Ingersoll-RandEvolution Rage2, 40 amp PlasmaLincoln 225 AC/DC
Reply:Just a guess but it might be an 8018 due to the tensile and and the idea of an "igniter tip"but it is just a guess.  By the condition of the can there will be flux in the can that has come off of the rod. It says good for all steels so it should work.
Reply:May be a discontinued part, I can't find it in the current Techniweld catalog:  http://www.techniweld.com/products.htmYou might be able to send them an email inquiry and get the comploete scoop.- MondoMember, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:Many proprietary rods from manufacturers like Certanium, etc. don't have AWS numbers, and aren't approved for code work. As said, they are probably similar to an 8018 and should work fine for most non-code work.
Reply:Thanks - just tought i would give it a shotThe main thing is not to panic or get excited Bobcat 250, X-Treme 12VS,  MM211Meltabo, Milwaukee,Porter Cable,Dewalt,MakitaVictor O/A, Ingersoll-RandEvolution Rage2, 40 amp PlasmaLincoln 225 AC/DC
Reply:You've got their phone number. You will  likely get quicker help on this if you call them tomorrow.CharleyMiller MM252Miller Bobcat 225NTMiller DialArc HF / DIY Cooler2 Victor O/A TorchsetsMilwaukee 8" Metal SawMilwaukee Dry Cut "Chop" Saw 5 Ton Wallace Gantry Various Grinders, Benders, etc.
Reply:Renagade  -  a  "Rod is a rod is a rod is a rod".I want to know about the Exclusive Ignitor Tip.Opus
Reply:Originally Posted by OPUS FERRORenagade  -  a  "Rod is a rod is a rod is a rod".I want to know about the Exclusive Ignitor Tip.Opus
GMT+8, 2025-12-25 07:49 , Processed in 0.071020 second(s), 18 queries .
