Dual Shield?
发表于 2021-8-31 23:41:38 | 显示全部楼层 |阅读模式
What exactly is dual shield wire? Is it just running gas with your flux core, or is it all together different? We run the stuff at work and I notice my overall weld quality is much better. I can't seem to find the stuff to fit my little 110v though. (Miller 130xp)Just another clown trying to be cool
Reply:Dual shield is a wire (filler) specifically designed to run with both a shielding gas and the shielding properties contained in the flux. So no it isn't only a self shielded flux core with a gas.A 120 volt machine won't be running any dual shield. Not enough balls.  http://www.esabna.com/EUWeb/AWTC/Lesson7_2.htm
Reply:Its a gas shielded flux cored welding wire.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:With your 110v mig, you're limited to .035 self shield wire at the most.  Dual shield wires don't start untill 1/16 wire dia and bigger.  You need a 220v 250 amp machine at minimum to run the smallest dual shield wire.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Originally Posted by DesertRider33 Dual shield wires don't start untill 1/16 wire dia and bigger.
Reply:Ihave used a several different alloys and brands of gas shielded flux cored at 0.035 and .0.045.
Reply:Here are some samples of smaller Dia wire.http://www.lincolnelectric.com/produ...-selection.asp
Reply:I have used esab dual shield 7100 ultra in .035, .045 and .052.  The .035 was run on a miller 185, the .045 and .052 was run on 250 and up floor units and remote units in the shop.  I have also run the .045 through a ln25 and 12vs from a trailblazer 302.  I love esab wire.
Reply:I run 7100 lc in a lincoln 175 but it doenst run the best and is maxed out on power. I really need a xmt !
Reply:dual shield is pretty much badass and yeah it comes in everything from .035-3/32(that's the biggest I've used) Esab wire =my fav too
Reply:Originally Posted by Scott YoungI have used esab dual shield 7100 ultra in .035, .045 and .052.  The .035 was run on a miller 185, the .045 and .052 was run on 250 and up floor units and remote units in the shop.  I have also run the .045 through a ln25 and 12vs from a trailblazer 302.  I love esab wire.
Reply:Sorry DR33 but I believe you are mistaken...I have ran pallets of Hobart Bros Fabco 110 in .045 using either an LN-25 tied onto an Invertec V-350 Pro, or with a PowerMig 350MP.Nice Stuff in the correct application.Have a Good DayLater,Jason
Reply:Originally Posted by 7bicksHow did the 185 perform with the .035 setup?  I am curious as I like dual shield but just don't  have the $$ for a 350MP.
GMT+8, 2025-12-25 09:40 , Processed in 0.093023 second(s), 18 queries .
