What do you think this is?
发表于 2021-8-31 23:41:36 | 显示全部楼层 |阅读模式
What do you guys think this is for? My father bought it as a PTO powered water pump. To pump out water from a river but it never worked right so I think it something else. Anyone got an idea what it could be? Attached ImagesAdam MMorales Ranch
Reply:It's a water pump.
Reply:BlowerTA PAK 5XRTA 185Lincoln Wirematic 250
Reply:I,ll second that, looks like a blower with suction port on each side and a double entry impeller so as not to need a thrust bearing as such. ( If you submerged the blower so that the suction ports were below the water it would pump, but totally not what it was designed for,Last edited by gordon stephenson; 02-07-2011 at 04:57 PM.Lincoln SP-170 MigHypertherm powermax 45Lorch T220 AC/DC TigButters FM 215 synergic MigKemppi 180 adaptive mig RULES ARE FOR THE OBEDIENCE OF FOOLS AND THE  GUIDANCE OF WISE MEN.
Reply:It surly has to be home made right? Do you guys know of any companies making something like this?Adam MMorales Ranch
Reply:Snow blower???? LOLAWS certified welding inspectorAWS certified welder
Reply:llamafur is right.  It's a submersible water pump.  We use them for large volume water transfer up to 9000gpm at low pressures.  Ours are powered by 6 cylinder Deutz air cooled drivers but can be configured for PTO driven as well.http://williamsfire.com/product/44b6...ncer_9000.aspxMM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:It's a pto water pump. We have several around here. Some tractors have pto's that turn clockwise and counter clockwise, so make sure the pto is turning the pump in the right direction. Second thing to check is the impeller for wear. It's a very simple pump to work on, and they do work well.
Reply:It's hard to see in the pic. Where does the water come off the pump and get to the simese connection?Miller thunderbolt 250Decastar 135ERecovering tool-o-holic ESAB OAI have been interested or involved in Electrical, Fire Alarm, Auto, Marine, Welding, Electronics ETC to name a just a few. So YES you can own too many tools.
Reply:How many feet of head are you trying to pump with it. The pump Duane showed only pumped 13.9 psi which isn't a lot.
Reply:Looks very similar to a trailer pump I have. Mine has one 20 inch discharge built of the impeller case. It will pump 14,000 gallons per minute. Lincoln electric has plans for it in one of there project books.
Reply:after doing a bunch more searching I found out its a trailer mounted water pump thats PTO powered. It meant to move ALOT of gallons Adam MMorales Ranch
Reply:Submersible Pump no doubt.
Reply:They use em in Alabama and Arkansas to aireate the ponds for catfish and other products.  The put that pump in and turn it with a PTO and it throws the water a good distance into the air and that cleans and oxygenates the water so the product continues to grow and thrive.  See em all the time on small farms.BobI'm spending my Kids inheritance, I dont like him that much anyway!!!!!!Enuff tools to do the job, enough sense to use em.Anybody got a spare set of kidneys?  Trade?
Reply:they use to use them here in kentucky..  near where i live is a wildlife management area, they used to pump water from a creek and flood standing timber for duck season... was a blast hunting in it.. they pump an enormous amount of water.... seems like i remember the conservation officer say it was like 10,000 gallons per minute...  they had a big diesel pto drive unit that ran it 24/7 for about a month...adding this, they use these in arkansas also to flood rice fields. if you run it, add a good safety cage around it..Last edited by brucer; 02-11-2011 at 09:20 PM.tackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
Reply:Originally Posted by cajun welderIt's a pto water pump. We have several around here. Some tractors have pto's that turn clockwise and counter clockwise, so make sure the pto is turning the pump in the right direction. Second thing to check is the impeller for wear. It's a very simple pump to work on, and they do work well.
GMT+8, 2025-12-25 11:25 , Processed in 0.103828 second(s), 18 queries .
