Wrecked feather lite stock trailer rebuild
发表于 2021-8-31 23:41:34 | 显示全部楼层 |阅读模式
This trailer came in from Geogia, it was in a wreck and had ripped the neck off, bent the top out of square, and alot of other things that had to be replaced and repaired!!Just some of my work! Attached Images
Reply:kool those are some expensive trailers newAdam MMorales Ranch
Reply:looks goodtackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
Reply:The guy had about $ 9000.00 in it when we were done, he said it sold new for around $ 16'000.00  the trailer didn't have but about 1000 miles on it when it was wrecked, so he was very happy.
Reply:Good job. How much of that repair was aluminum, and how much was steel?City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:I have a featherlite horse trailer and from my experience you had your work cut out for you and you did a hell of a job!Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:The only steel was the coupler, it is bolted in, we took it out replaced the coupler and bolted it back in, the rest was aluminum. The skins were put back on with solid aluminum brad style rivets, and the rest was welded with a spool gun, alot of work went into it, but it was actually fun, different from most of my work.
Reply:Looks great, fantastic repair!Gordhttp://gordsgarage.wordpress.com/
Reply:looks gr8 man, i had a similar job this last summer but it was a Barret alum. stock trailer, it had blown around a farm yard by '' STRAIGHTLINE WINDS'' according to the news, but ive nevver heard of that being possible,  rolling the trailer side over side 4 times and endo 2 times landing it on top off a 36 ft air drill, my guy bought it back from ins. co. for bout 1500.00 and my bill was round 1000.00 and now he has two of them one brand new nad the other as a spare or backup trailer not bad for 2500.00 instead of paying 18,000 for a new one like the ins. co. had to. if i can figure out how i will post up some of my project pics, kwMM 251MM 135Lincoln Pro cut 55Bobcat 250Miller Thunderbolt ac/dcolder ac forneyJackson nexgen 3n13-Smith OP setups97 Dodge dieselMakita chopsawJet swivel head bandsawlincoln tig 300/30030a spoolgunpuma port. gas air comp.
Reply:Thats a hell of a good job!!!!
Reply:I like how you staggered the seam from the side to roof seams. Helps with strength, water and fit up.Did you get to cash in on the scrap aluminum?  Your gas bottle should be tied up lol. At least its capped
Reply:Originally Posted by oxygen454I like how you staggered the seam from the side to roof seams. Helps with strength, water and fit up.Did you get to cash in on the scrap aluminum?  Your gas bottle should be tied up lol. At least its capped
Reply:Nice. Aluminum scrap can add up fast.
Reply:Did you buy the parts from fetherlite or another supplier?Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Originally Posted by DualieDid you buy the parts from fetherlite or another supplier?
Reply:thats some nice work.If you like my stuff you can find me on Facebook.  https://www.facebook.com/theangryanv...ngryanvilforge
GMT+8, 2025-12-25 11:34 , Processed in 0.139209 second(s), 18 queries .
