Mig pics
发表于 2021-8-31 23:41:32 | 显示全部楼层 |阅读模式
been in welding school for 2 months and but I have welded before when i was in the military but here is some pics of some stuff i did today3/8  mild steel v-grove open rootplease comment good or bad if anything it will make me better..thanks
Reply:i will take pics of the bend test tomorrow which came out very good
Reply:not bad. For your weave cover, make your zig zag a lot tighter, don't move so far ahead.
Reply:Originally Posted by Hertznot bad. For your weave cover, make your zig zag a lot tighter, don't move so far ahead.
Reply:Your root looks great,  Its almost laid in there almost money.  But your cap, well needs helps.   You need to increase your speed weave.  The weaves need to be closer.Lincoln 300 Vantage 2008300 Commander 1999SA250 1999SA200 1968Miller Syncrowave 200XMT350MPA/S-52E/xr-15Xtreme 12vs Millermatic 251 w/30A  Millermatic 251 Dialarc 250 Hypertherm 1250 GEKA & Bantom Ironwokers
Reply:Id disagree, the root is in need of some help too. Looks like you were going way to fast, with a long arc length.Slow it down some and keep the tip just as close as you can in the groove.  This wil he eliminate the suckup, ensure that all the edges are broken down and that you get better reinforcement.These were on pipe, but its the same idea.  I generally prefer to do a 2 bead cap, depending on how wide the face opening is.Have we all gone mad?
Reply:beautiful cap !
GMT+8, 2025-12-25 09:40 , Processed in 0.087691 second(s), 18 queries .
