Water Tank
发表于 2021-8-31 23:41:30 | 显示全部楼层 |阅读模式
I have a 1979 international single axle dump.  I want to fabricate a 2000 gallon water tank that will slide into the back of the dump.  I have been looking for designs on the web and just have not seen any.Design thoughts:>>>Access to the inside for welding and painting>>>Baffles ???>>>Lifting hooks for easy installation and removal>>>Have thought of just purchasing a $1200 plastic tank???Any help or ideas would be great.Moose
Reply:I'd opt for the $1200 plastic tank.I wouldn't like the thought of having to paint the inside of a steel tank.You wont have to paint or weld the inside of a plastic tank.
Reply:By the time you price out the cost of materials for the 2000 gallon steel tank, the $1200 plastic one will probably be a no brainer. The plastic one will be easier to load and unload off the truck when you want to also. But if you just have to have a metal tank, consider aluminum or stainless steel, no worries about painting it then. But you could buy several of the plastic ones for that price, and that's before you even start cutting and welding. Whatcha wanna haul 2000 gallons of water for/to, if you don't mind me asking? Watering cattle, fighting fires, filling a remote swimming pool, conducting big "Wet T Shirt" contests?????
Reply:What about going used? http://www.ebay.com/itm/Used-5000-Ga...47f989&vxp=mtrDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:I just went thru this at work. We went with a plastic, 2750 gal tank for around $3000.00 new. Rough figure is a dollar per gallon but ours came with steel tube straps and a baffle. Steel is great until it starts rusting thru. Also, you would need to bend the steel for strength. Will a single axle truck hold 8 tons of water?"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Out of curiosity, what is the weight for a gallon of water? never mind 8.33 pound I found it in my book  thanks.Miller thunderbolt 250Decastar 135ERecovering tool-o-holic ESAB OAI have been interested or involved in Electrical, Fire Alarm, Auto, Marine, Welding, Electronics ETC to name a just a few. So YES you can own too many tools.
Reply:I have a 6 " well and its just not big enough to water lawn and all my trees, we have had some dry summers.  Close to the lake, so the extra PTO and a water pump with tank should work out fine.  The truck is a hauling machine,  I put heavy springs on it, it has a double frame.  At 12,000 pounds empty, I have come over the scales at 29,000 that's 8 1/2 tons.  Water at 8 pounds a gallon thats 8 ton.  This old International is a real workhorse,  put GM Throttle Body Injection on last year and it purrs like a kitten.
Reply:[QUOTE=moosejaw;1746721 The truck is a hauling machine,  At 12,000 pounds empty, I have come over the scales at 29,000 that's 8 1/2 tons.  Water at 8 pounds a gallon thats 8 ton.  This old International is a real workhorse,  put GM Throttle Body Injection on last year and it purrs like a kitten.[/QUOTE]8 tons for 2000 gallons of water doesn't leave much leeway for the weight of the tank in the truck. Not to mention your pump and hoses to go along with it, not that they would add a whole lot though.The plastic tank will weigh less than the metal one most likely.
Reply:I vote plastic. Corrosion and rust is a real problem. The good ones last forever. Likely cheaper too.
Reply:Plastic. Easy to take off and on when the truck is needed for something else.
Reply:Plastic is way lighter and no rust.  Get the black tank that algae doesn't grow inside of, they stay WAY cleaner.Lincoln 250 IdealarcLincolc 255 PowermigLincoln SA 200 1940's with V4 WiscLincoln SA 200 1974 blackface
GMT+8, 2025-12-25 09:41 , Processed in 0.110589 second(s), 18 queries .
