welding table 20"x70"... not wide enough? or go for the 4'x4' table
发表于 2021-8-31 23:41:29 | 显示全部楼层 |阅读模式
local CL has a 5/8" thick welding table that looks pretty stout.Would the fact that its only 20" wide be a huge limitation? also see a 1/2" 4'x4' table, doesn't look quite as rigid but i could opt for that instead. Similar price on both tablesESAB Heliarc 252
Reply:Any table is better than working off the floor.  For myself I'd go with the 4x4, should be big enough for most things, mine is about that size and thickness, had it about 20 years, so far so good."The reason we are here is that we are not all there"SA 200Idealarc TM 300 300MM 200MM 25130a SpoolgunPrecision Tig 375Invertec V350 ProSC-32 CS 12 Wire FeederOxweld/Purox O/AArcAirHypertherm Powermax 85LN25
Reply:Go with the 4x4.Dave ReberWadsworth Ohio
Reply:4x4 if you have the space. or make the space.
Reply:Paying for the top not the base.  You modify/replace the base.  More surface square foot in 4x4, too.  So even if you had to modify the top you still have more metal to work with.
Reply:thanks, may go and buy it today if I can get out of work for a whileESAB Heliarc 252
GMT+8, 2025-12-25 09:40 , Processed in 0.105224 second(s), 18 queries .
