tig welding stainless steel
发表于 2021-8-31 23:41:24 | 显示全部楼层 |阅读模式
how do you prevent that hole that sometimes developes at the end of your tig weld?
Reply:if you are using a foot pedal gradually reduce the heat dont just snap it off if your not using a foot pedal quickly break the arc by snapping the torch side ways then bring it back over the weld for the shielding gas to do its job and dont worry if it makes a loud pop noise that is just the arc breaking
Reply:+1 and put an extra dip of wire at your stop
GMT+8, 2025-12-25 09:39 , Processed in 0.070524 second(s), 18 queries .
