Build a Propane Pipe Burner
发表于 2021-8-31 23:41:17 | 显示全部楼层 |阅读模式
Anyone have the knowledge that can show/tell me how to build a propane Burner to control heat on a large BBQ smoker?
Reply:Unless you're going to use forced air, you'll probably want to copy the long propane burners that come under restaurant griddles.  They have a small venturi funnel at the front where the propane is injected, and then a series of holes along either side of the pipe where the flames come out.  Try looking at Ron Reil's website for information on the pressures/orifice sizes/etc for the venturi.  Sorry I have no idea how to match the size of the burner holes to the intake... you'll probably need to experiment or talk to someone with some fluid dynamics background.Weld well; grind less.
Reply:check out the hobart forum. a guy made a pretty cool one http://hobartwelders.com/weldtalk/sh...hlight=propanePound to fit, paint to match
Reply:Originally Posted by tigmuskycheck out the hobart forum. a guy made a pretty cool one http://hobartwelders.com/weldtalk/sh...hlight=propane
Reply:Here's two different styles that I've built.This one is the style where you get a bunch of little flames on a tube.http://nanosleep.dyndns.org/griddleThis is the style where you get one major flame!http://nanosleep.dyndns.org/deepFryerDynasty200DX w/coolmate1MM210MM VintageESAB miniarc161ltsLincoln AC225Victor O/A, Smith AW1ACutmaster 81IR 2475N7.5FPRage3Jancy USA1019" SBAEAD-200LE
GMT+8, 2025-12-25 09:39 , Processed in 0.067918 second(s), 18 queries .
