How to get my shop approved?
发表于 2021-8-31 23:41:16 | 显示全部楼层 |阅读模式
So, I want to bid on a job for the state, and on the plans there's a note that reads:"A.  FABRICATION OF ALL STRUCTURAL STEEL SHALL BE DONE IN THE SHOP OFAN APPROVED FABRICATOR. INSPECTION AND APPROVAL FOR FABRICATOR'S SHOPS USED FOR FABRICATION OF STRUCTURAL LOAD BEARING MEMBERS, COMPONENTS, MATERIALS OR ASSEMBLIES SHALL CONFORM TO CBC SECTION 1704.2."So here's the code:"1704.2.2 Fabricator approval. Special inspections required by this code are not required where the work is done on the premises of a fabricator registered and approved to perform such work without special inspection. Approval shall be based upon review of the fabricator’s written procedural and quality control manuals and periodic auditing of fabrication practices by an approved special inspection agency. At completion of fabrication, the approved fabricator shall submit a certificate of compliance to the building official stating that the work was performed in accordance with the approved construction documents."Where do I get written procedural and QC manuals? Would the AWS D1.1 or lincoln procedure handbook work for this purpose? Where do I find a special inspection agency qualified to inspect my shop?Ian TannerKawasaki KX450 and many other fine tools
Reply:sounds like one of those certs that lets you double your rates for the jobs that require it miller syncrowave 250hobart handler 140home made 400 amp engine driven in progress...
Reply:Check out the AISC site too, the last shop I worked in had that and we got a ton of jobs.http://www.aisc.org/Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Is the 1704 code you reference a state code? I can't tell by your post. I'm sure there is a process thru the state to get on the approved list. We  have been thru this process several times not only for approval for different types of work but for dollar amounts. Could these guys help with some of the inspection work???http://ats-slo.com/services.htmlLast edited by dunemetal; 11-03-2012 at 09:30 AM.
Reply:theres more in the structural notes than what you have posted hereVantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
GMT+8, 2025-12-25 09:39 , Processed in 0.093469 second(s), 18 queries .
