Ford ZF5 weldable?
发表于 2021-8-31 23:41:14 | 显示全部楼层 |阅读模式
I'm searching for a 7.3 diesel donor truck to transplant into an older truck and came across a good deal on a wrecked 96. The truck went off the road and drove sideways into a tree and twisted the frame in the center (real bad). The only drivetrain damage was the starter got whacked off and took a chunk of the bellhousing with it (just immediately around the starter). The bellhousing is integral to the transmission (one peice construction) so unless it's weldable the transmission needs replacing. I've done a search on used transmissions and people are asking what I'm paying for the whole truck!
Reply:That is common around here. The local guys weld up those trans. all the time. Longevity is something I don't know about.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:The case is weldable. The later cases have big time porosity--more thanthe older ones (which makes them more fragile), takes more time to dealwith the porosity.When things break, the casting first stretches and distorts, finally breaking.Getting good starter alignment, a really flat, square and perpendicularflange mounting surface can be tough. The starter mount holes may bejacked as well.On crashed vehicles, there often is hidden damage in the casesthat isn't discovered until the case is removed from the vehicle--cracks,broken bosses, ripped out tapped holes, etc. This is more the casethan not, in my experience.Blackbird
Reply:incorrect assessment of the situation. the starter bolts to the front of the adapter plate, and the transmission bolts to the back, which parts are broken? adapter plates are a dime a dozen, if you will pay shipping I will give you one.ps unless you are saying the bump where the nosecone goes has broken off, then you might need both adapter and case repair or replacementLast edited by turk; 11-04-2012 at 06:01 PM.Dynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
Reply:Thanks for all the quick replies!Turk, I'm not 100% sure. I haven't gone to look at the truck yet becasue it's a couple hours away from me. I did have the seller take a picture of the damage and send it to me. What does this look like to you; adapter or transmission? Attached Images
Reply:thats the adapterDynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
Reply:Its one of the most common things that is welded here in my shop...
GMT+8, 2025-12-25 09:39 , Processed in 0.090047 second(s), 18 queries .
