Anyone used Passport + spool gun with alumimum
发表于 2021-8-31 23:41:11 | 显示全部楼层 |阅读模式
Would like to here how hard or easy the passport is with aluminum?I'm goin for it. Be here middle of next week. I have use on one arm, so tig is out. The spoolmate 100 is $206 from Cyberweld. Passport will be from local welding shop (Phoenix welding - on order). My wife changes the wire for me. She's getting quite good. I might order 2 spool guns. Why? I'll keep 035 in the passport. .025 in one spoolgun and aluminum in the other.Looking at Al projects and having fun this new year.Projects in top menu: http://wwwenichesoftware.comVern
Reply:Can't say how it might do with aluminum as I have the older model Passport that isn't spool gun compatible, but I know you'll love welding with it on steel.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:"My wife changes the wire for me. She's getting quite good." You got a great wife there that shows she's interested in the stuff  you do,does she do welding as well? My wife would rather iron skillet me if I asked her for her help with welding lolDrink a Guinness Draught....Millermatic 140Do you still rememberDecember's foggy freeze --when the ice thatclings on to your beard isscreaming agony.
Reply:Originally Posted by Vern2Looking at Al projects and having fun this new year.Projects in top menu: http://wwwenichesoftware.comVern
Reply:Sorry, I screwed up the link. http://www.enichesoftware.comVern
Reply:Did find this. [ame]http://www.youtube.com/watch?v=V_MiGrL9350[/ame][ame]http://www.youtube.com/watch?v=KCxGeyJvQsU[/ame]VernLast edited by Vern2; 01-10-2010 at 09:47 AM.
Reply:It works great Vern.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Vern,Since you mentioned only have use of one arm and the Mrs. having to change the wire you may want to hold off on the 2nd Spoolgun.Swapping the regular gun with the Spoolgun takes a little bit of effort to make sure the Guns are seated correctly.For over all ease of work flow I would be tempted to keep the Passport connected with the Spoolgun for AL and .023 Solid wire in the Sp135Plus and whatever other wire you fancy in the SP175 Plus.The MM212 may be worth the extra $ as it can have BOTH a Spoolgun and a Regular gun connected at the same time- Gun on Demand system- just pick up which ever gun you want to use and the machine activates that Gun.Of course the MM212 is not a Portable machine.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Along those lines, the Millermatic 251, 252 and 350/350P can have one roll of wire and mig gun on the machine, another roll of wire in the spool gun, and another roll of wire and mig gun on a Reach feeder, by swapping the 10-pin plug back and forth between the spool gun and Reach feeder so you can have  3 machines in one, welding 3 different types of metal with a different gas bottle connected to each device all at the same time.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:The MM212 works with the Reach alsoEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:I get a stupid idea about every 10 minutes. I'm 65, but I have a young person locked up inside me. I try to live life to the fullest. Slide in, body all used up, die having fun! Your right about double spool guns. Looks like I'm keeping SP175 plus, selling Sp135 plus ($450 to $500 craigs list). I'll place the PP+ in the shop on the other side of 10 foot steel (only 3/16 plate) over 3/4 plywood. sp175 with 8" .035 c25. PP+ with .024 4"spool with internal co2. Spoolmate aluminum with external argon. I think material select switch, will switch gas for me. I'll switch guns.THANK YOU BULLDOG for pictures!This is passport plus 120v 14 gage aluminum.This is passport plus 120v 3/16 aluminum.I'll be doing 1/8", except for adding 1/2" x 1/16 AL tube across 2 1/8" square OD (I'm making)  x 1/8" thick x 3" long. I may reinforce both ends of tube with 1/8 plate. The ID of pipe is 3/8", just right for my pivot. for tilt legs. I'll take pictures when done (24 each)VernLast edited by Vern2; 01-10-2010 at 10:10 PM.
Reply:Hey Vern those are some nice welds...BobBob WrightSalem, Ohio  Birthplace of the Silver & Deming Drillhttp://groups.yahoo.com/group/southbend10k/http://groups.yahoo.com/group/sawking/1999 Miller MM185 w/ Miller 185 Spoolmate spoolgun
Reply:There is a toggle switch inside the Passport to switch between the internal CO2 bottle and the incomming gas line from an external bottle.  The mode switch on the front of the machine changes the arc characteristics for each metal type (inductance).MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:vern,the Material selection switch DOES NOT change the gas supply- that has to be done manually.I put a set of Quick Disconnects on my machines and Hoses to make swapping Bottles easier.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:What I'm meaning is, switching from internal (co2) to external argun).
Reply:Originally Posted by Vern2What I'm meaning is, switching from internal (co2) to external argun).
GMT+8, 2025-12-25 09:39 , Processed in 0.068470 second(s), 18 queries .
