A few weeks ago someone was complaining about spatter using CO2 gas. I cant find the original post. I promised that I would take photos of the miller book showing the effect of adding inductance to the welding circuit.Notice that the lower set of photos of the bead are much smoother because of the added inductance. Attached Images
Reply:If your MIG does not have an inductance setting, you can add inductance by coiling the work lead around a chunk of steel. Crude, but it can help.
Reply:You must be working too hard since you already posted this info in the thread you can't findhttp://weldingweb.com/vbb/showthread.php?t=36340&page=2Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Thank you for the info.Tim Beeker. |
