Plow repair. Royal PIA
发表于 2021-8-31 23:41:04 | 显示全部楼层 |阅读模式
My trusty rusty old Fisher 9' plow (94 vintage) has more holes in the front than good metal so rather then start welding a dozen patches on it, I decided to re-skin the front.  I had a new piece cut and rolled so it was a perfect fit.  The plow weighs a ton as it is so I did not wish to just add the new face over the old rot so I started cutting the old face off.  This is proving to be more of a challange then I anticipated. 5 hours and only 2/3rds there.  Perhaps I should have just delt with the extra weight.  I know that once the old one is off the new will be a piece of cake but whew, that's a lot of work.  Still, it is cheaper then a new plow.
Reply:Know what you mean. My 9' Fisher will need a new skin soon. The snow foil is in worse shape though and will need some attention before the season starts. It's getting towards time all that needs to get addressed. Probably drag it over to the shop and work on it around Thanksgiving the way things look right now.What did the new skin cost you?.No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:The foil on mine is in tough shape also but I no longer use this plow for road work, just my own driveway so I might just leave it off.  I don't remember what it cost as I paid cash and it's been standing in the corner for over a year.  It was not expensive.  Stock plus cut and roll fee.I started by trying to cut through the welds on the back side and taking it off in small chunks.  That was just pissing me off.  So I shifted gears and located the welds on the front and drew circles around them, then cut the circles with my plasma cutter.  Then it started moving much faster.  With the bulk of the old skin out of the way, the small parts left behind are much easier to deal with.  There is about twice as many welds holding that face on then I anticipated.  So be forwarned
Reply:On my 10' Western I just bolted a piece of 3/8 plastic dump truck liner right over it , Snow slides off slick as snot.Miller 180,Esab 300I TIG Lincoln Stick [1950's} Victor Torches, Dewalt chop saw, Enco 9x48 Mill,  48x60 home shop with Gantry crane and Pit.
Reply:It is a $hit job plain and simple, a 3 foot torch, screw dogs and a BFH are your friend. I did a TD-7 dozer reskin in less time than an 8' Fisher blade.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:"Screw dogs (I call them jacks) are a HUGE time saver. They'll do what a clamp won't & when you're done, just cut the tacks off & hit it with a grinder. Good to go."Thick head here......can you 'splain it better?
Reply:I solved those kind of problems by moving 1600 miles south. MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Thanks!....your a good 'splainerLansing gets snow?Being 20 miles south/south east of Lake Michigan,when the conditions are right we get some snow.
Reply:Originally Posted by duaneb55I solved those kind of problems by moving 1600 miles south.
Reply:Originally Posted by vwguy3Thanks!....your a good 'splainerLansing gets snow?Being 20 miles south/south east of Lake Michigan,when the conditions are right we get some snow.
Reply:"Glad I could 'splain that for you"Sometimes it take some extra 'splainin for me to understand
Reply:I had to Google "Snow Plow"Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:So many projects with so little time.  I just finished tacking this up.  I had to make some threaded J hooks and drill a bunch of holes in the face so that I could suck this up tight to the ribs.  I won't do this job again.  I'm sure there's a cheap used plow someplace and I should have explored that route first.  It did come out nice. Just a lot of work.
Reply:I found one on Craigslist for 100$Niiiiiice shape with a relatively new cutting edge..Needed nothing except a swap to my MM1 headgear.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by zapsterI found one on Craigslist for 100$Niiiiiice shape with a relatively new cutting edge..Needed nothing except a swap to my MM1 headgear.....zap!
GMT+8, 2025-12-25 09:41 , Processed in 0.098239 second(s), 18 queries .
